Question about Samsung 50 in. Plasma TV
I have a Samsung 50" Plasma TV (PS50C96HDX/XEU). The problem with it is that: 1) It can only be switched on via the On/Off button in front ot the TV 2) It does not respond to the remote control 3) It only responds to one or two buttons on the side of the TV 4) It changes source from TV to AV to DVD all by itself.
  • 11 more comments
  • rol2y Feb 03, 2009
    I have bought and tried a new PCB Main Board with no success.
    Please what is the IR board?
    Is the IR board same as the PCB Logic Board?
    I need to know what parts I need to change or action I need to take to solve the problem then I will accept.
    I already tried all the minor troubleshooting like changing batteries.
    It also does not respond to the batteries on the side of the TV itself. And on its own, it changes channels and source of input.
    It also does not respond to the buttons on the side of the TV itself. And on its own, it changes channels and source of input.
    The remote control is not the problem. The remote control works perfectly with my Sony VCR.
    The TV ALSOM DOES NOT RESPOND TO THE SIDE BUTTONS ON THE TV.
    The TV ALSO DOES NOT RESPOND TO THE SIDE BUTTONS ON THE TV.
    I HAVE BOUGHT A BRAND NEW PCB. IT DID NOT SOLVE THE PROBLEM. I STILL HAVE IT WITH ME.
    PICTURE QUALITY IS OKAY BUT THE TV CONTINUES TO CHANGE CHANNELS ON ITS OWN. NO RESPONSE TO BUTTONS ON TV OR REMOTE CONTROL.
    SINCE PICTURE QUALITY IS GOOD, AND I HAVE ELIMINATED THE PCB MAIN, WOULD YOU ADVICE I CHANGE THE PCB LOGIC MAIN AND THE PCB POWER SUPPLY BOARD?
    Ronnieh49,
    When you say change both boards, do you mean I should change the PCB Logic Main and the PCB Power Supply boards?
    Is this same as complete rebuild? Because since the picture and colour is okay that should mean the PCB Y boards are okay?
    I am ready to accept once I get confirmation.
    I am going to carry out the recommendation of Ronnieh49 that I should change both boards. I pray it does work. I will come back to rate this after I have tried the solution.
  • rol2y Feb 24, 2009
    Problem finally solved. Not the PCB Mian Board, Logic Board or Power board. The problem, the Powerbutton/IR sensor board.
    I disconnected the Powerbutton/IR sensor board et voila!! the dise control buttons all working perfectly now. All I need do now is change the IR sensor board. Itsy bitsy thing to cause all these problems n'est pas?
  • 6,784 Answers
Unfortunately you have major board issues and possibly many solder break points.i recommend a total rebuild. if you have a warranty, i would defiantly use it immediately.
Posted on Feb 03, 2009
  • Michael Masters
    Michael Masters Feb 03, 2009
    absolutely. that will work.
  • Michael Masters
    pcb logic main rebuild is certain. the power board is fine.
    Genius:
  • 2,920 Answers
Buy an all in one remote for you tv dvd player etc.they set up for anything you may have and only cost about 10.00. the original remote may not be working if the batteries are low or its lost its code. its hard to say which. try the all in one remote and see if that dosent solve the problem
  • 1 more comment
  • Ronnie Houston Feb 03, 2009
    yes you should change both boards
    you have confirmation
    thank you for trusting my judgement and accepting my solution.
  • 565 Answers
Buy yourself a universal remote and use it with your tv
  • Samsung Master
  • 13,433 Answers
Hi
Change the batterys in your remote controller, check for stuck buttons, check the battery contacts and that they are the right way in there. sometimes the batterys might not touch the contacts properly and the remote wouldn't get power.
How old is it? got warranty on it?
    President:
  • 2,559 Answers
The ir board is going bad.
  • Randy Hough
    Randy Hough Feb 03, 2009
    This is the PCB,The IR is located on this board and could be a loose soldier joint or a bad component
  • Randy Hough
    You should also check the control board that the ir sensor and buttons are connected to.
Hi my samsung plasma ps50c96hdx/xeu powering down, pressing power button has no effect to turn on again.Powers up by unplugging 5min then starts working. now powering down more frequently. Please help
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time; especially to Plasma displays. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 12, 2015 | Samsung Televison & Video
Samsungtantuatvwenturnonthegreenkgreen light blink for cople seconds then went off i hear a click sound
i have a samsung tv model ps50c96hdx/xeu which keeps switching of everytime i switch it on
Jan 27, 2013 | Samsung LN40A650A LCD TV
Model Samsung PS50C96HDX/XEU
I assure, the sound is ok. Try changing the input device.
Jul 29, 2012 | Samsung Televison & Video
Our Samsung HPN5039x Plasma TV isn't turning on: when we press the power button, the red power light flashes then turns off. What do we do?
Hello, It sounds like you have a defective power supply. Typically, +5 volt stby is present if the TV switches on with front indicator light. On the power supply, connector 802 pin 4 is the on command from the pcb main to switch the p.supply on. If this signal is present but still no VS,VA,VE panel voltages are missing, the p. supply is bad. Good luck!
Bill W.
integrityhomeworx.com
Dec 24, 2010 | Samsung HPN5039 50 in. Plasma HDTV
Short circuit on the "Y" sustain board
The problem is heat!!! If the tv has fans they should be checked for normal operation,although on the early samsung models there were none, and the problem is that the panel drive buffers are getting to hot due to inadequate cooling. This is most apperent when tv is mounted to close to the wall, also external fan blowing on the rear left side will dissapate the heat. It is a problem on early Samsung and Electrograph 42 " plasma models. Hope this helps.
Jul 28, 2010 | Samsung Televison & Video
Service manual for samsung ps50c96hdx
i have a samsung model ps50c96hdx/xeu which keeps switching of when you put it on
Aug 26, 2009 | Televison & Video
Samsung  50 in. Plasma TV Logo
80 people viewed this question
Jerry Greenberg
Jerry Greenberg
