Question about Braun Flex XP II 5790 Electric Shaver
Shaver suddenly stopped working
I have a 6 month old contour 5780 that i purchased from target. i regularly clean and charge it in the base system.
today i removed the razor from the base and when i pressed the start button it worked for about .5 seconds and quit. i took it apart and cleaned it, inspected the circuit board and tried to run it again apart from the body...nothing. it is dead as a dead duck.
i am almost 100% certain that it is charged fully.
did the motor burn out? did the circuit board fry? can i acquire a new one from braun since it is only appx 6 months old?
  • 3 more comments
  • Anonymous Feb 03, 2009
    same problems
    mine is one year old did the samething
  • Anonymous Mar 29, 2009
    Green light is lit. Yellow light doesn't come on. Shaver isn't charging
  • Anonymous Apr 11, 2009
    same problem also
  • Anonymous Apr 25, 2009
    I hit the silver reset button and it now works
I had the same problem with mine right after the two year warranty expired.
BUT I FIXED IT!!!
The problem seems to be bad engineering. Apparently the cleaning solution works its way into the circuit board of the shaver.
I took the razor apart (you need very small phillips screwdrivers), there are six screws. First remove the foils, then the blades (just pull them up). Two screws are where the head rotates. after removing the head, there are two more screws underneath the head. There are two more screws on the bottom under plastic caps beside the charging terminal. You can now gently slide the razor's hardware out of the case by pulling up on the head mounting arms while holding the case as you normally would shaving. (This sounds confusing but should be obvious as you do it.)
Looking at the circuit board i noticed some white residue on the board. I gently cleaned the board with small amount of alcohol and q-tips, being careful not to catch any cotton on the components of the board. At this point you can at least confirm that the motor is not burnt out and the batteries are charged by placing a flathead screwdriver between the positive terminal of the battery and the motor. It should come on if the motor and batteries are okay.
Next you hit the reset button at the bottom-front, then see if it comes on using the on/off button. You can do this step with the razor disassembled or assembled.
Hopefully this works for you. Now if only i could figure out a way to clean and refill the cartridges instead of paying $5 for 5 cents worth of cleaning fluid.
Posted on Jan 24, 2010
  • gsbarry Jan 24, 2010
    I should add that my razor is the braun contour, series 3, 5790.
    I think I also had to plug it in before I hit the reset button and turned it on. I can't remember exactly though. It has worked fine since.
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
Can't get the 7526 cleaning arm to stay down on the shaver for charging, cleaning, etc. Is there a sequence e.g. hold the arm down then select a cycle, or select then push down? What is the blue button...
The locking mechanism in the arm is broken. This is a common problem with your model. To repair it you will need to purchase a replacement part. You will find the part at shaveroutlet.com. See link below
If repairing your existing clean and charge machine is not an option, you will find the entire machine available at the link below
May 08, 2011 | Braun Syncro 7526 Electric Shaver
My base does not pump cleaning solution thru the device. I will run the entire process, & there will be clippings in the bottom of the slot where the razor sits. The solution container is full, but...
The pump in the cleaning maching is broken. Pumps are not available seperately. Your only option is to purchase a new cleaning /charging machine. You will find this item for model 7570 available at shaveroutlet.com. See link below
Mar 06, 2011 | Braun Syncro 7570 Electric Shaver
The arcitec that I have stopped work- ing a few months after I purchased it. It doesn't run, like the battery is dead. I ran across it a couple of days ago and thought I'd try to use it again. But no...
In older models if you leave it plugged in it will ruin the battery. It has to be unplugged after it is charged. Unfortunately it sounds like the battery is bad. Contact a service center to see if the battery can be replaced otherwise you may need to buy a new unit. The newer self cleaning models do not need to be unplugged after cleaning and charging.
Jan 09, 2011 | Norelco Arcitec Electric Shaver with Jet...
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Sep 25, 2010 | Braun Health & Beauty
Shaver will not charge or clean in the base
All you have to do is take the base apart. Turn it upside down, and there are two plastic clips on the rear portion of the base. Press them in with a key or screwdriver and wiggle the base a bit to remove the inner portion from the outer shell. Make sure you unplug the unit and remove the cleaning cartridge before doing this. Once it is apart, place a small wedge underneath the portion of the electric contact that sticks out to touch the shaver, and press the back of that portion out so that it slightly bends the contact strip and makes it stick out a little further. Then remove the wedge and put the base back together. It will work again, as the contacts can now protrude to touch the shaver and run the cleaning and charging cycle.
Jan 22, 2008 | Braun 360° Complete 8985 Electric Shaver
Braun Shaver 360 Complete #8985
the 110 plugin goes into a circuit which changes AC to DC for charging the internal NiCad batteries. If there is NO charge whatsoever in the batteries, the shaver will not work. If you have any electronics background a simple test with a VOM will determine if the bridge rectifier is putting out any DC.[you must disassemble the shaver] If you have no experience on circuits take it to a repair location.
Sep 10, 2007 | Braun 360° Complete 8985 Electric Shaver
It keeps flashing CHARGE
Return the shaver to the store from which you purchased from. It would appear that one or more of the Ni Cad batteries are no good and will not accept a charge. Have you attempt to plug the charger directly into the shaver? If not, try that and see if the shaver will run. Still your best move is to return the unit to the store as it is still under store return warranty. Dutchman
Aug 28, 2006 | Norelco 7800XLCC Electric Shaver
Braun Flex XP II 5790 Electric Shaver Logo
3,133 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
