Question about Hansgrohe 06649860 Solaris Single Hole Kitchen Faucet with Base Plate - Ste...
Water is plugged by minerals etc in my Hansgrohe kitchen faucet
I cannot figure out how to take it apart to clean the filter(s). i did remove the filter in the end but it is still partially plugged.
  • Anonymous Mar 31, 2014
    plugged faucet how remove drain plug
  • 34 Answers
You will need a flat head or a knife. You sould be able to pry it apart if not they are so cheap, pick one up at walmart, lowes etc. Bring the old one with you. Some of the tread patterns are diffrent
Posted on Feb 04, 2009
How do I get more water pressure from a Tuscany model 673-6070 kitchen faucet?
Remove the spray head and clean the filter screen it may have particles of mineral from the plumbing clogging it.
Nov 26, 2016 | Plumbing
How do you remove the Metris S wideset faucet handle?
To remove the handle simply rotate the escutcheon counter clockwise and it will unthread from the fixation on top of the counter. Then the handle will lift off as one unit. You can clean them with CLR to clear up water deposits. If you need further instructions feel free to contact me Hansgrohe Tech 1-800-334-0455 press 2 for Technical and ask for David Scarborough. I'll be happy to help.
Apr 08, 2013 | Hansgrohe 31063821 Brushed Nickel Metris S...
Dismantle the handle plug
Most Hansgrohe faucets or handles have a plug in them. This does not come apart but in most cases you simply push the plug into the handle and once you have removed the hendle you can retrieve the plug from inside the handle or on top of the faucet. If you need further help fell free to contact Hansgrohe Tech at 1-800-334-0455 press 2 for Technical.
Apr 05, 2013 | Hansgrohe Plumbing
How do I fix a leaking hansgrohe solaris bathroom faucet?
If this is a widespread faucet you will need to turn the bell shaped portion of the handle counter clockwise to remove the handle as one unit. Then you will see the hex nut of the cartridge that will unscrew counter clockwise to remove. If this is a single hole unit you will need to loosen the set screw on the handle to remove it and then remove a cover ring to access the cartridge nut. If you need any further assistance feel free to call me at Hansgrohe. 1-800-334-0455 press 2 for Tech and ask for David Scarborough. I'll be happy to help.
May 25, 2012 | Hansgrohe Plumbing
Water Ridge Nannini series pull out kitchen faucet rotating at base instead of where it should.
I just fixed our Nannini from Costco. The screens were plugged with plastic filings coming from our water lines. On our faucet there is more than one screen.
The pull out faucet has the basic screen like 99% of the taps out, right on the end. It comes apart by first unscrewing it from the handle and gently (gently) nudging the screen out with a sharp object such as a pairing knife.
Then in the handle was where the problem lay with mine. There was a plastic knob which is recessed in the handle. Leave the hose connected and pull it out until it is stretched or have a helper, then press on that small knob, pull and the whole inside will pull out. There is another filter in there. I was able to take mine apart and clean it, yes it does pop apart but be careful. In assembling mine I just left out the second filter totally.
I guess in hindsite you wouldn't have to actually take the whole handle apart if one has a 90 degree tool to pull out the yellow plastic piece. I used an allen wrench and pulled. Cleaned it with a small needle.
Works better than new!
Nov 24, 2011 | Moen Plumbing
The water pressure in the entire house is very poor. If more than one water tap is open the water trickles out. The house has a Culligan Water Softner system. Is there a filter or some other home...
First make sure all the filters on all faucets (kitchen, bathrooms and even the dish washer and washer) are clean and not clogged, sometimes on areas with hard water you will experience sand and minerals to accumulate and clogged all filters. If all filter are clean with no minerals, then your problem could be the culligan filter, ask your sales rep to perform an inspection for minerals on all ending lines.
Hope this clear up your water lines. It happened to me.
Aug 09, 2011 | Culligan 34" Whole House Water Filter...
We have a screen inside of the nozzle that we can not get to. We've tried with a tooth pick etc. When there is a water outtage and they turn back on the water it sends a rush of junk and we have to be...
The screen is held in place by a threaded piece on the end of the faucet - collectively the screen along with the threaded piece is called the aerator. The aerator must be unscrewed to remove and clean the screen. A pair of pliers or a pipe wrench may be necessary if the aerator is tightened beyond hand tight or if corroded with mineral deposits.
Have you been able to remove the aerator?
May 01, 2011 | Delta Palo Single Handle PullOut Kitchen...
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
Hansgrohe Kitchen Faucet low water pressure
Try removing the aerator and handspray to clean out any debris that may have accumulated. After 8 years there could be quite a buildup if it hasn't been regularly cleaned.
May 24, 2010 | Plumbing
Hansgrohe kitchen faucet 20 years old
No problem. I need the manual for the 20 year old faucet so I can remove the cap and grease the arm action' The unit is a Hans Grohe vintage 1998.
Sep 23, 2008 | Hansgrohe Plumbing
Hansgrohe 06649860 Solaris Single Hole Kitchen Faucet with Base Plate - Ste... Logo
581 people viewed this question
Top Hansgrohe Plumbing Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
