Question about Konica Minolta magicolor 2300DL Laser Printer
Where can I order parts for konica minolta 2430 dl?
I need to order part number 4139630602 the switch that detects the toner cartridges
  • 10,865 Answers
Here is there website for parts. please rate my answer. thanks
Posted on Feb 03, 2009
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Cannot revolve cartridges
Doing a complete power off/on and following the notes on Konica/Minolta website for changing cartridge
Jan 27, 2009 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Consumables for Konica Fax 100
If it's the Konica 2430/2480, try the following page, it has the parts list you need.
Aug 25, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Jul 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 2430 DL Xtoner not installed
Check the toner contacts in the printer, you may find one either dirty , bent or broken.
May 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
193 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
