Question about QuietLine WD-9900 Front Load Washer / Dryer
Hotpoint BDW 12 wont hold on a spin or dry cycle
The control Knob then clicks through all the cycles and wont stop
  • 350 Answers
Dear sheridan pet,
A lot of TIMERS just get to much gunk in them!
With the OLD TIMERS you could open it up and spray it with a can of electrical cleaner (same as they sell for computers) and a lot of the time it would fix the problem!
This may also work on your circuit boards in a new appliance just be sure to read and follow the directions carefully!
I recommend Radio Shack for advice & purchase!
Cost about $10.
I'd open it up and if nothing else obvious look broke I'd buy a can of cleaner and give it a try!
Good Luck!
jackiaria
Hope This Will FixYa!!!! Please Rate Me!!!
Posted on Feb 03, 2009
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
Washing wont fast spin and empty
Possible that the control has failed and so does not instruct the main board to control the spin and continue with the drain.
Need to check the voltage on the controller and the drain pump at the cycle to confirm this case.
Jul 25, 2012 | Whirlpool Washing Machines
Bosch classixx 6 1400 machine stopped working during cycle f21 on display
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Nov 27, 2010 | Bosch Washing Machines
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Aug 24, 2010 | Baumatic 23 in. BDW3 Built-in Dishwasher
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
QuietLine WD-9900 Front Load Washer / Dryer Logo
139 people viewed this question
Top QuietLine Washing Machines Experts
Are you a QuietLine Washing Machine Expert? Answer questions, earn points and help others
