Question about Panasonic KX-FP101 Plain Paper Thermal Fax
When the fax machine rings to indicate an incoming fax...
We have to press the start/copy button in order to be able to receive the fax. I should be able to set the fax machine so that it is able to receive calls at all hours, not just when someone is here to "start" it.
Thank you in advance for your much needed assistance :)
  • 93 Answers
Hi
it appears that the fax machine is in manual receive mode!!
you need to put the machine in auto mode or auto answer or auto receive mode with the reception mode or auto answer button next to the LCD display!!
Posted on Feb 09, 2009
Hello! How to program automatic reception of a fax after 4 calls (at the weekends, when at office anybody isn't present. Thank you. Best regards, Veronika
hi; Receiving Both Documents and Telephone Calls Automatically: Fax/Tel Mode If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings: ??? Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting). ??? Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting). ??? Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting). 1 Press [Menu]. 2 Use [{] or [}] to select <DATA REGSTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>. 3 Use [{] or [}] to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>. 4 Use [{] or [}] to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>. 5 Press [Start/Copy]. 6 Use the numeric buttons, or [{] or [}] to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. 7 Use the numeric buttons, or [{] or [}] to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>. Note ??? If paper jams, see "Troubleshooting" on page 53. ??? If the Ink Lamp lights up faxes will be received to memory. 8SEC. 22SEC. Use [{] or [}] to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6. 9 Press [Stop]. Setting ends and the fax returns to standby mode.
Oct 14, 2010 | Canon FAX-JX200
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
I want to receive fax message with just one incoming ring.
press the following
function-7-monitor button 4 times, then start [*]- should say service mode then press 1 then 4-5-then start-start - clear then 1 then start then stop - stop
Jan 20, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I have just puchased a new Fax machine, I only have one telephone line but when I sent the machine to Fax/Tel the machine takes over and keeps ringing until i press tele/Rev..I want to receive incoming...
I always setup my faxes with FAXONLY mode,I set the incomming ring to "on "and ring count to "7".
And check wat is your remote rx number-with that number you can dail it and it will go to fax automaticly.
Nov 04, 2008 | Brother Office Equipment & Supplies
Canon Fax Phone
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 12, 2008 | Canon FAX-JX200
Just brought a Fax JX200 and am having great diffuclty working out a problem , problem being we also have a 2 phone dual handset and the problem is when the phone rings it goes straight to fax on all 3...
1. Press [Menu].
9. Press [Stop].
Aug 11, 2008 | Office Equipment & Supplies
Not sure how to setup the tel/fax mode correctly
1. Press [Menu].
9. Press [Stop].
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jul 31, 2008 | Canon FAX-JX200
Cannon Fax JX200
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which appears to be your setting, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls based upon the times that are input in the settings of the machine. It would seem that the best thing to do would be to lengthen the times involved - particularly at step 7 below. I would imagine it is set at a low number - perhaps 10 seconds or less - and needs to be increased to give you sufficient time to answer the call.
1. Press [Menu].
9. Press [Stop].
It may take a few rounds of going through these steps to get the settings just right for your situation, but it should definitely solve your problem. If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution.Thank you for using and rating FixYa!
Jul 13, 2008 | Canon FAX-JX200
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Panasonic KX-FP101 Plain Paper Thermal Fax Logo
155 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
