Question about Kyocera Mita FS 1010 Laser Printer
Different label alignment on different printers
Where can the printer alignment/margins be set?
IBM client access version 5.8 is being used to print labels on various Kyocera Mita FS 1010 printers. The 1"X4" labels are two (2) columns by ten (10) rows on an eight-and-a-half (8.5) inch by eleven (11) inch sheet of labels. Depending on the printer, the top alignment of the label text can vary by an eighth (1/8) inch or more.
All of the know Client Access settings are identical between the printers being used. However, there does not appear to be any setting(s) that directly effect printre alignment and/or margins.
    Genius:
  • 2,120 Answers
Right click on the printer icon and choose properties
Posted on Feb 04, 2009
Label print problem making in MS word
You need to set up the paper print size for the Cannon. It may be a different print height and width.
Feb 27, 2014 | Canon LASER SHOT LBP-2900 Printer
My printer s4m is printing one side of the label the alignment is far right on the label
Check the size of the label that you are using if you are using label design software. If you are using another software, check your left margin setting. Hope this helps!
Aug 18, 2011 | Zebra S4M Thermal Label Printer
At school there is a printer the Dell 5100cn laser printer and we need to print labels and each time we try it asks on the computer if I want to continue because they are outside of the standard margins,...
A5 is a European paper size standard. Your label making program is telling the printer that the program needs that size label paper. You have to tell the printer to use that size paper. It may be somewhere in the menu of the printer driver on the computer or it may be on the display window on the printer, or it may be as simple as flipping a tab in the paper tray. As far as the printing outside the standard margins, most printers will allow a certain amount of that without a problem. Just tell it yes or Ok. If you solve the paper size problem and it hangs up when you tell it to print outside the margins, then the printer is not compatible with that label format in the label printing program. You will have to choose a different format. I recommend that you select a label format that is a US standard like 3 across on 8 1/2 x 11 paper.
Nov 19, 2010 | Dell 5100cn Laser Printer
HP photosmart 8250 is printing different margins
ok..do us a favor here..try a test page from printer selection panel. just to make sure it's not the printer..you may need to re install new printer drivers.
Nov 28, 2009 | HP Photosmart 8250 InkJet Printer
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Printer setup
Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
Dec 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Page size for CD printing
I think that the CD/DVD printing ability depends on the software that epson bundles with the printer.
I had the EPSON R200 and i could only print CD's from the EPSON PrintCD software.
May 04, 2008 | Epson Stylus Photo R260 InkJet Printer
Bottom Margin Cut Off! :(
Your printer prints Letter format. Set the printer to A4 standard printing. As I remeber this tab is in the printer in the country/region section. Select your language and as a country select the Cech Rep. Is one of the countryes that uses A4 standard
Nov 15, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Kyocera Mita FS 1010 Laser Printer Logo
271 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
