Question about HP Pavilion dv6000z Notebook
Can't get a pc signal to lcd-tv
Nothing happens with the hook-up.
    Novelist:
  • 155 Answers
Some more info would be useful...
HP laptop s have a key combo to switch the display between internal and external - have you tried this?
On my HP laptop it is Fn and F4. This should toggle between internal only, external only and internal/external both on.
Posted on Feb 03, 2009
  • HP Master
  • 13,433 Answers
Hi
Ok, just need to enable the extra output and you will get picture on the tv.
Try this first
right click on desktop and select properties then follow the video to enable the extra display. If this doesn't solve the problem let me know and there are other things we can try.
http://www.svideo.com/displayvideo.html
No signal cable TV
if you hooked up the coaxial in the RF tuner then you can not get signal, the cause will be the tuner has problem.
Aug 15, 2012 | Panasonic Viera TC-L37U22 37" 1080p...
I cant get any color when i hook up my x box orginal.. tv color works fine.. i have tried plugging the white into the blue and nothing happens.. What needs to be done to be able to have color when im on...
White is your audio signal, not video. If you are using a composite hook up, yellow is your video and needs to go in the yellow slot. White and red is your left and right audio. If you are using a component hook up, then you will need to use red, green and blue for video and white and red for audio.
Apr 11, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
Will not play on new RCA LCD TV tried different
Try hooking up your sony handycam to a different monitor or tv to make sure it is putting out a good video signal using an S-Video cable. Then once you know your cords are good and you have a good video signal, hook it back up to the RCA LCD unit. If it is still not working make sure that the RCA LCD is set to receive the Hi8 signal via the S-Video cable. There may be a switch or menu setting on your RCA LCD to accept the Hi8 signal or also refered to as S- Video.
I hoped that helped and good luck!
Nov 16, 2009 | Sony Handycam CCD-TRV68 Camcorder
Picture goes off and on every couple of seconds
If you are hooked up to a HD source if the signal is too high will cause this to happen. Normally this will happen due to signal interuptions such as signal being low will cause freeze, too high will cause it to go out and cause the TV to show default blue.
Good luck to you.
Sep 20, 2009 | Memorex MLT1921 19 in. LCD TV
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
"Unusable Signal"
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.ebc3c7f.jpg
Mar 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
Lcd hdtv is hooked up to laptop but it is every 10 sec gos black
if theres nothing happening on ur pc like same as tv its probably the tv config ...
check tv setup
check tv screen saver..if it disabled it would explain why screen black...
could try checking power settings in pc(screensaver properties)
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Trying to connect PC to Philips LCD HDTV
While the tv is on the right input, and the computer is running, try unhooking the cable and hooking it back in. That's the only way I can get my Philips to detect the HDMI signal from my pc. I haven't found a fix for it though.
Jan 29, 2008 | Philips 37PF9996 37 in. HD-Ready LCD...
HP Pavilion dv6000z Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
