Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Dishwasher won't start rinse cycle
Sgs 66E02 gb. My dishwasher washes but does not start the rinse cycle, it sounds like it is pumping out all the time. The timer sits @ 1min but if you open the door it will reset to start of rinse cycle.
If the water is switching off at the correct level to initiate the wash cycle and assuming that the water is not being pumped out continuously after that, i would say you have an electronic control problem. there should not be any changes taking place on the display when opening the door
Posted on Aug 15, 2007
  • 641 Answers
It sound that the problem is cause the water switch level. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Posted on Aug 03, 2007
Why does by dishwasher not cycle through
The timer controls the electro-mechanical components in the dishwasher such as the wash pump, drain pump, inlet water valve and heating element. The timer also advances the control knob on the control panel. Replace the timer if it fails to start and stop the components properly or fails to advance the control knob. Dishwasher Won
Oct 26, 2017 | Frigidaire Dishwashers
Machine starts fills Ok but when it clicks on to start the wash pump, nothing happens, I can hear a faint hum. When cancelling wash and starting new wash it pumps out ok too. After rinse cycle it indicates...
sounds like your main circulation pump is not working, if it is humming when it is supposed to start, sounds like it is getiing power, so probably not the control circuits, can you measure voltage to pump?
if you are getting 120 there, probably pump motor is dead
Mar 02, 2013 | Asko D1876 Dishwasher
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
My Bosch dishwasher (model sgs 3062gb) has suddenly started taking much longer to complete a cycle. It would appear to be taking over an hour on the pre-rinse section, but then carries on as normal....
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 11, 2011 | Bosch Dishwashers
Rinse cycle doesn't pump out
Sounds like the drain pump needs replacing.
Have a serviceman check to prove this is the problem.
Jul 29, 2009 | Dishwashers
Kitchenaid dishwasher makes a crunching sound during rinse cycle
Sounds like a bearing in the pump is going. This would cause a leak be careful leak will get worst.
Sep 18, 2017 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwasher just emptying
I am at the end of my tether. I have bought a new door latch for my Bosch SGS 43E02 GB45, so door now closes properly and have managed to stop the leak under the front left hand side of the machine. Howver it sounds as if it is constantly emptying. It does not go onto the new wash cycle just keeps pumping out the water. It did run a quick rinse yestreday but now is back to the constant emptying problem. Even when I open the door it still keeps running and staying on a emptying cycle despite there being no visible water left inside the machine. Please help!!
Sep 12, 2008 | Dishwashers
No water going in to dishwasher when rinsing
the pump shouldn't turn on when the rinse cycle is on - it uses only fresh water straight from the water line - after the wash cycle is over - wait 5 seconds, then open the doors and see if there is any rinse coming out of the rinse arms.
If only a little is coming out - check the rinse arm spray jets to see if there is debris caught in them -
if no water is coming out - it could be a faulty rinse solenoid
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
212 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
