Question about ECHO, Inc. PB-251C Handheld Blower
ECHO blower won't pull
It ran fine. packed it in the back of the truck and travelled. Went to run it and the it won't I pulled the side cover off and checked the cord. It is fine. Nothing will turn. What would cause it to lock up like this and how can I fix it? And i always use mixed fuel in it. I use the same fuel for my string trimmer and chain saws.
  • elpescador24 Mar 18, 2009
    i have a pb 200 echo handheld blower.when i use it last it worked fine.now.a week later when i went to start it.the reciol handle wouldn't pull.its lock. i haven't dropped the blower or abused it...
  • 23 Answers
I think i know how to fix it.. :)
Its got a compression lock. take off the spark plug and pull the rope.
Dont forget to rate me back please! -Jeff -Anchorage Small Engine.
Posted on Feb 04, 2009
  • Edward Pyznar Oct 01, 2012
    Worked Great, thanks
My back pack was running then shut off and now cant pull cord to re-start it
You ran it lean and now it seized up from the friction caused by heat caused by lack of lubrication
Nov 15, 2013 | Echo Garden
Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Oct 24, 2012 | Garden
ECHO PB251 BLOWER. Noticed fuel running out of muffler. Cleaned spark screen, installed new airfilter, fuel vent, fuel filter. Ran unit - engine quit while at full rpms - will not start. Clicking noise...
Your flywheel has come loose on enj., this throws the timing off so it is firing at all different times except for when it's supposed to. therefore raw fuel is running right through the cylinder and out exhaust, If you are lucky you won't have to replace the 60.00 flywheel! remove fan side of case,and remove blower wheel, then flywheel nut then flywheel, it has a built in key in it, usually this is wasted from coming loose, make sure you use loctite and an impact to tighten flywheel nut back after you repair/replace flywheel.
Dec 04, 2011 | Garden
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
My echo backpack leaf blower pull start seems stuck it wont crank
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Aug 30, 2011 | Echo Pb - 413t Backpack Blower
I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Sep 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Can't get my Echo PB251 Blower to rev up at all, unit is 8 mo.s old was running fine now all of a sudden won't rev up, I have changed plug gas filter,cleaned all filters including spark arrestor changed...
guarantee exhaust is clogged maybe not muffler but exhaust port pull muffler off check screen and muffler then look into exhaust port usually rectangular port is closed down with carbon pull starter slowly to lower piston then scrape out carbon with screwdriver clean as good as possible then blow cylinder out make sure to get all pieces of carbon out reassemble should run fine
Jun 14, 2009 | ECHO, Inc. PB-251C Handheld Blower
Runs fine &then suddenly stops
IN the tank there is a intake tube on the bottem of that tube is a tiny filter. you can reach in and pull it out the tank enough to work on it.
It is clogged pull it off let it dry for a day and then blow it clean fron the gas line side OUT.
or echo sells tune up kits for 10 bucks at home depot. -Jeff Anchorage Small Engine.
Dec 24, 2008 | ECHO, Inc. PB-251C Handheld Blower
ECHO, Inc. PB-251C Handheld Blower Logo
1,087 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
