Question about Frigidaire ATF6000ES Front Load Washer
While spinning; washer moves
When I put the spin cycle to maximum, the machine rocks and moves frontwards. My husband checked to make sure it is level. I thought the front load machines weren't supposed to do this.
  • 640 Answers
If new did you remove shipping bolts,,,is the floor wood ,,or weak...did you set the log bolts on the legs,,,it sounds like you installed this your self..keep me posted onthejob
Posted on Feb 05, 2009
Washer rocks during spin cycle
sounds like u need to balance it by adjusting the legs and then use a leveler to see if its balanced
Mar 23, 2015 | Washing Machines
Samsung front loader rocks on spin cycle, sometimes, it is level
I assume you removed the transit packing!! or the technician did - but double check there are no bolts that need to be removed from the drum, or polystyrene blocks still underneath that were not removed. See the installation instructions.
If you are sure the machine is solid on the floor, it may be a suspension problem, or suspension dampers. But check again that the machine is sitting solid on its feet / wheels - grab the case and try and move the machine backwards and forwards, left and right. There must be NO MOVEMENT or rocking AT ALL when you try this - adjust the feet or pack as necessary
Feb 02, 2018 | Samsung Washing Machines
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
Jul 09, 2017 | Maytag Atlantis MAV6260AWW Top Load Washer
Washer sounds like it has rocks in it during spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Whirlpool GHW9100L Front Load Washer
I have a Maytag Atlantis washer that runs fine until the spin cycle. Once it hits the spin cycle, it gets very loud, like it's off balance. When we get the clothes out, they're still soaking.
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Washing Machines
On the spin cycle my miele walks acrossed the floor
Aug 06, 2009 | Washing Machines
Maytag lat6914aae top load washer shakes violently in spin cycle
A washer can have self leveling legs at the back. If they are rusty or clogged and not free to move, they will not self level and the machine will rock when working. Check the leveling apparatus, it's a bunch of metal pieces going across the lower back of the machine. Spray them with a lubricant and move them to make sure they are free.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
New machine, manual says run a spin cycle, can't figure it out
make sure you remove all the shipping bolts per installation instructions then rock washer with hand and screw legs down till it doesn't rock then load an go call me back if any problems
Dec 30, 2007 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Frigidaire ATF6000ES Front Load Washer Logo
169 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
