My Inkjet 2800 won't print DWG. (CAD) files. I have no problem with other files; word, excel, photos ... When I try a CAD file, the printer shows "printer error."
  • 596 Answers
Does the printer show you Printer error with number and letters following it? Prior to printing, check the 'print preview' to see how the layout of the printing is showing. If the CAD drawing is not adjusted to fit on the paper in the printer, you may from time to time get a printer error.
Posted on Feb 03, 2009
Corrupt DWG files
AutoCAD RECOVER command?
If doesn't help, try it:
DWG Repair Kit
This professional AutoCAD DWG repair tool features a uniquely efficient data analysis core and an interface that both professionals and novices with appreciate. The program will show you how to repair DWG files online in seconds even if you have never worked with data recovery tools of any sort!
For more information: http://www.dwg.repair/
Also look here: https://social.technet.microsoft.com/Forums/en-US/fb2d8693-9551-43b7-9310-584471d60a56/autocad-files-corrupted?forum=w7itproappcompat
Feb 17, 2015 | Autodesk AutoCAD 2007
How to recover AutoCAD files from flesh card?
If you need to recover it as fast as it possible install Recovery Toolbox for DWG , this thing is able to help you. But it's not free. Download free demo here:
http://www.dwg.recoverytoolbox.com/
As one of solutions I can advise you to try to open your files in MS Visio, Compass or using another program which could open dwg file. Or try to recover them using AutoCAD recovery function.
Also you can read here about dwg file corruption:
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/561-how-to-recover-autocad-files-from-flesh-card
Nov 27, 2014 | AcroCAD Software AutoCAD DWG to PDF...
.dwg file corrupt?
Different solutions you may find out here:-
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/444-%E2%80%8Berror-cannot-open-file-open-cad-drawing-dwg-format - a lot of different opinions might be your saving.
BAK files are very important, explanation below:
Consider what AutoCAD does during a QSAVE (assuming "create BAK" is enabled)
1. It writes the contents of the editor to a temp file.
2. It renames the current drawing from .DWG to .BAK
3. It renames the temp file to the correct file name with a .DWG extension.
I don't see how you have had problems with BAK files since it's simply a copy of your last save. In fact, if you QSAVE twice in a row, then your BAK = the DWG.
OR
Third party software DWG Viewer Tool
But demo version for free:- http://www.dwg.viewertool.com/
Nov 06, 2014 | Autodesk AutoCAD Computers & Internet
What software do I need to convert word, jpg and other files to PDF format?
The easiest way I've found is to use CutePDF. It installs itself as a virtual printer, only when you "print" to it, you get a PDF document output. Download it for free here http://www.cutepdf.com/products/cutepdf/writer.asp
Feb 04, 2011 | HP Computers & Internet
How do I get an HP 9800 Deskjet to print dgn/dwg files?
Download and install the FREE Bentlley View program which will allow you to print DGN files.
http://www.bentley.com/en-US/Products/Bentley+View/Product-Overview.htm
Let me know if this resolves your issue.
Thanks for using FixYa!
Apr 07, 2009 | HP DeskJet 9800 InkJet Printer
How do you lock a dwg file so it cannot be edited?
A COUPLE OF SUGGESTION
Now you can protect your works with this DWGLock software, the entities in the send out drawings can NOT be copied nor changed. However, recipients can open up the drawing, add lines and markups. Only the drawing owner allows extracting the drawing, if they need to, enclosing the added part with the native drawing. This is ideal solution for the collaboration needs and contractors.
It is a stand-alone application, no AutoCAD required; Supports AutoCAD R2.9 thru 2009 drawings. about $330.
CADLock, Inc. continues to create innovative solutions that enable you to maintain control of your intellectual property and share it with those who need it. We invite you to download and evaluate CADVault® for AutoCAD® to find out how digital rights management can work for you. THIS MAYBE PRICY also
Acme CAD Converter Acme CAD Converter is a dwg/dxf/dwf format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF,JPEG, DXF, DWG, SVG , PDF, HPGL etc., and also enable the conversion between DXF and DWG file versions (R2.5-R2005).
Apr 01, 2009 | Autodesk Map 3D 2006
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
