Question about NEC ETW 16DC-1 Corded Phone
Settings I have the NEC ETW 16DD-1 phones, I am trying to set the correct Time. How do I get Into the settings menu?
  • 63 Answers
If you have a nec electra elite system go to the operators phone and hit feature key then dial 9 #
Posted on Feb 16, 2009
Why is my display is flashing "BATTERY LOW" where is the battery located?
Look on the bottom for a door to access the batteries. If all else fails go to the manual you received with the phone and follow its instructions.
Apr 28, 2014 | NEC Electra Professional Etw-16dd-1 /...
I need to change the time on my nec phone, but every solution on the web uses the "feature" button. My phone doesn't have a "feature" button. It is an etw-16dc-2(bk) telephone,...
you probably have an ext unit please try the following steps
To set the time, Press FNC then 9 then # then set the hr and mins using number keys Use RECALL button to set AM & PM Press FNC again to set.
Good luck and best regards
John
Mar 14, 2011 | NEC Electra Professional ETW-16DC-2
Cant change time on nec etw phone
Try this:
NEC Electra Telephone System
Changing the time on a Electra Elite & Professional system must be done from the "main" or primary phone. It is usually extension # 100. 1.- Press "FEATURE" 2.- Dial "9#" 3.- Enter hour and minute 4.- Press "RECALL" to change AM/PM setting 5.- Press "HOLD" to change the calendar setting 6.- Press "RECALL" to change the day of week 7.- Dial "#" to move the cursor to day of month field 8.- Enter day of month 9.- Press "RECALL" to select month 10.- Dial "#"to move the cursor to year field 11.- Enter last 2 digits of year 12.- Press "FEATURE"
Carl
Nov 06, 2009 | NEC Electra Professional ETW-16DC-2
How do i change the time on nec etw-16dc-1 phone
( FNC ) 9, # ... from the first port on the system.
Set the new time and the press ( FNC ) again.
I would like to know how to program numbers and recall these numbers on my phone
The Buttons must be set up as speed dial in the PBX if they are then its a simple process
Mar 04, 2009 | NEC ETW 16DD-1 Corded Phone (necetw16dd1)
Can't find caller id function on NEC ETW-16DC-1 BUSINESS PHONES SYSTEM
You have to make sure the phone system you have has CID cards in it. What kind of card is in the Electra phone system.
Sep 08, 2008 | NEC ETW 16DC-1 Corded Phone
How to program a line to ring keysets
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Apr 08, 2008 | NEC Electra Professional ETW-16DC-2
How to activate mic phone
Feature 1 or function 1 will work
Mar 04, 2008 | NEC Electra Professional ETW-16DC-2
Nec etw 8-2
FNC 1 toggles microphone on and off on the ETW-8 phone
Jan 24, 2008 | NEC ETW 8-2 Corded Phone
Set Time DTH-16D-1 (BK) TEL
Here's how you adjust the time:
1. Press <TRANSFER>
2. Press <CONF>
3. Press *
4. Press <TRANSFER>
5. Press <CONF>
6. Press #
7. "CAT MODE" displayed on LCD
8. Press <REDIAL or LNR/SPD>
9. "COMMAND" displayed on LCD
10. Press 02
11. Press <RECALL>
12. Press 2
13. Press <RECALL>
14. "02>2>Current Time" displayed on LCD
15. Input correct time using military time (HH MM SS)
16. Press <CONF>
Dec 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC ETW 16DC-1 Corded Phone Logo
394 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
