Question about Zanussi FJS1225W Front Load Washer
Main bearing gone
How do i change main bearing and seal
    Scholar:
  • 99 Answers
This is joyce
Hey dont do it seriously unless you are really good, mine went out and it took them 2 hours to fix mine, very ugly.
but if you are bent on fixing it go to zanussi.com and put in your model# and download your manual and it should tell you how to do this.
thanks
joyce
Posted on Feb 07, 2009
How. To change Rear main seal
remove gear box and flywheel for starters if the rear seal is in a case then remove that case and fit new seal. If it is a lip seal the remove the old seal and check the crank shaft for a groove. IT is grooved use a "speedie" sleeve ( trade mark name) from a bearing /seal supplier and then fit the new seal using a quality seal fitting tool.
If the rear main seal is the old two piece seal/ felt seal then you will have to virtually remove the crank to do the job properly.
Oct 10, 2014 | Cars & Trucks
Hi there, I have a Honda nsr MC21. I have been told that my crankshaft bearings/seal has gone. The bike wont start, if I spray/leak a little fuel directly into the carbs, it starts like a dream. I was told...
Difficult starting is a classic example of a faulty centre seal.The seals tend to harden up and leak after time and particularly with certain fuels.
Oct 22, 2013 | 1991 Honda NSR 250 MC 21
Main bearing seal
You gotta remove the trans to get at the rear main seal(yeah,it's a pain).Gone are the days of using one of those "rope style" replacement seals(like on a small block Chevy) that you can slip in by just removing the pan(aint progress great!)
May 26, 2012 | 2001 Nissan Sentra
My machine has brown spots of grease/oil appearing on the floor beneath it. The machine is still functioning but it is much louder than it used to be when filling and spinning. The model number is...
those brown spot are rust your main seal is failing if too far gone your washer will be noisy on spin suggest you replace bearing and seal before shaft is damaged hope this has helped let me know
Oct 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
2003 yz 250 leaking water from hole at water pump. does it mean bearings bad? and if so how do you change it. all i find is the cover or the propellar. i cant find the bearing
leaking water means the seal is gone, the bearing is in the clutch case, often needs a new shaft as well if it has wear marks, replace the bearing, it will help the new seal last longer
Apr 10, 2010 | 2003 Yamaha YZ 250
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
Mar 31, 2010 | LG WM1814CW Front Load Washer
What parts will I need when changing a flex plate?
While you have the transmission removed be sure to replace the rear main bearing seal.On a1982 you will have to remove the oil pan to replace the seal,It has a two piece seal.After removal of the oil pan carefully remove the back main bearing cap,you will have to use a straight pick to roll the top seal out of the block.Lubricate the deal with oil before you install it.Be sure to get a new oil pan gasket with your other parts.Make sure you torque your main bearing cap to manufacturer's specifications.
Jan 31, 2010 | 1982 Ford F 150
The bearings of my Dyson are gone. Are they
can it be fixed? yes.is it easy? no not by a long shot.there are two bearings in the drum one you will never get to needs factory tools to take apart. the other is the main steel bearing the drum spins on.now it is possable to get a patten mached bearing from a bearing supplyers but...this is just the bearing not the water seal and 9 out of 10 times its the water seal that go's and washes the greese out of the bearing and the bearing starts to rust and then grinds itself away and collapes!so it may fix it for a while 3-6 months at a push.plus the bearing is pushed into the drum on a large press like a car wheel bearing.i had to use a 50 ton press to fit my bearing back in! and as to getting the old one out well thats another story.lol alot of people don't have the time or skill to do this so they end up as scrap or on ebay.now i paid alot of money and fitted a stainless steel bearing into mine and its not had a problem in 10 months so if you do give it a go to replace the bearing thats the best way to go.
Jan 26, 2010 | Dyson Flowcheck CRO1 Front Load Washer
How do you change a rear main oil seal in a 2000 toyota celica gt
First of all, be certain that the leak is in fact from that seal. many leaks travel to that area.
To change the seal is fairly involved, you need to pull the trans and flywheel. There are some specialzed tools involved. Do you have manual or automatic? Manual requires clutch plate alignment on re assembly, by the way , if manual, be sure to change the release bearing and pilot bearing at minimum. Commonly it would make sense to change the clutch during this process....you're already all the way in there..
Sep 07, 2009 | 2000 Toyota Celica
Have to change bearing on front load washer
This link should get you on your way. http://www.applianceblog.com/washers/RearBearingV6.pdf
In addition I should mention that the original bearings are a shielded bearing (Z). Follow the link and use 6306-2RS and 6307-2RS bearings which are sealed. I was able to match up SKF 562737 seal which is now a CR 15939 seal I believe. It is completely rubber coated. Between the sealed bearings and new seal you should be good to go.
Dec 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
116 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Chris Hall
Chris Hall
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
