Question about Humminbird Computers & Internet
Connecting my HP Pavillion DV9500 laptop to my Samsung PS-42Q96HD
Hi there can anyone please help me? I have just bought some VGA 15pin male leads to wire up my laptop to the plasma TV. In addition i bought stereo phono leads in order to get the sound. I have managed to get a crystal clear image on the TV BUT there is no sound. The system on my laptop is VISTA. At the moment i have my XBOX (HD set up) and surround sound set up to the TV at the back but i have spare audio in sockets on the left side of the TV. I have connected the phono lead to the laptop in the headphone socket (tried both) at the front of the laptop and the white and red leads to the side of the TV. I have also tried other variations but still no sound. Might there be a problem because of the XBOX or surround sound set up? Or do i have to tinker with the Vista settings on my laptop? Can anyone please help me...really appreciate any help i can get on this...many thanks. Steve
  • Stephen Mistretta Feb 03, 2009
    Hi Info2u...i have the white and red leads plugged into the audio in. I have just tried what you have suggested on the TV menu but unfortunately to no avail, there wasn't an option to change it to stereo. Would it be anything about to do with the Vista settings on my sound control panel?? Thanks again....
  • 596 Answers
Sound more like your problem is with the connection to the TV. Make sure the connection at the TV is to an 'input' connector and not 'output'. Also, from the TV menu, if you can select the output the laptop is using make sure the sound is stereo an not 5.1 or 7.1 or something to that effect. All other connections seem to be in good shape. Good luck.
Posted on Feb 03, 2009
  • Nouveau IT, LLC
    Nouveau IT, LLC Feb 04, 2009
    OK, try the sound options within Vista. Check to make sure the sound is set for stereo and not headphones or notebook speakers. Also, check your media mixer and make sure none of the mute boxes are checked and the sliders are adjusted to a higher volume setting.
How do i connect to tv
use a 15pin male to male vga cable or you can use a simple s-video cable..most tv's should have s-video inputs, either method should work.
Dec 24, 2009 | HP Pavilion dv4000 Notebook
Lead from external harddrive to tv- to show films,--usb connection from harddrive to 15pin to tv
Dear ragalgey,
As far As I can remember, most TV design to receive the signal to watch whatever you want limited to available TV station in your local broadcaster.
If you think you connect your harddrive to TV USB or 15pin (VGA cable) then you can watch the movie file from harddrive is a totally wrong!
You need a drive or a player for those file that capable to configure your TV to play them. Or at least you need a PC or Laptop Computer that played your harddrive then send the images/video via Video Out Jack (Yellow) from your laptop, or connect the 15pin VGA jack from Laptop PC out then plug in to your TV. In this case you'll need the Jack/adapter to convert from 15pin VGA from laptop to available Video jack on your TV.
Good Luck!
Best Regards,
bionic23
Dec 08, 2009 | Samsung Computers & Internet
Having problems getting a full picture on my PS-42Q96HD
i have seen this before and it is the logic board failing
Dec 03, 2009 | Samsung HP-R4262 42 in. Plasma Television
Webcam not working on HP Pavillion dv9500
The trick to the HP web cams is the fact that they work with one piece of software only. Go to the HP support site...here...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01415015&cc=us&lc=en&dlc=en&product=3985345
scroll to the bottom of the page to the "see also" header. Choosethe download youcam file. It is a binary file that can be saved to your hard drive and then installed.
Sep 25, 2009 | HP Pavilion DV9500T Notebook
How to connect samsung pasma tv to pc?model number is PS42B450B1XUM
That does depend on the PC, but I'll assume it's a pretty standard PC.
You ideally need a Male 15Pin VGA cable to Male 15Pin VGA cable. (aka A normal Monitor Cable) The same as you probably have connected between your PC and Monitor.
Your TV has a 15Pin VGA Female socket on the back, this cable plugs into here.
For Sound the TV has what looks like a headphone socket next to the VGA Plug. You need to use a Stereo Jack Plug to Stereo Jack Plug Cable. 3.5mm. This goes from your PC's Audio Line Out (rear of the PC) to the Plug on the rear of the TV. It is usually marked Aux In or PC Sound.
Enjoy, The PC will look great on the Tv.
Sep 06, 2009 | Samsung Televison & Video
Hp pavillion dv9500 not turning on
some of the "boot" drivers might be lost jst check over it
Apr 04, 2009 | Computers & Internet
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Connecting my laptop to my new TV
Hi there.
Check on the back of the TV for a VGA input port, if it has what you will need is a male to male VGA lead and a mini stereo to mini stereo audio lead to plug into the headphone port on the laptop to audio in on the TV.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Compaq Computers & Internet
Unable to connect to samsung tv as monitor for hp laptop
Hi there
DSUB is VGA, has your TV got a VGA port on the back? if so and you know what the source the channel is then you will need a male to male VGA lead and a mini stereo jack to left and right male phono jacks for the audio, the DSUB or VGA does not carry audio through it.
Feb 12, 2009 | HP Pavilion dv2000t Notebook
Computers & Internet Logo
455 people viewed this question
Top Humminbird Computers & Internet Experts
Steve
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Humminbird Computer and Internet Expert? Answer questions, earn points and help others
