Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer too hot...no cool down
I recently replaced thethermal fuse on my maytag neptune MDE5500AYW. Now, it dries very, very hot, on any of the settings, and when it reaches the cool down stage, it does not cool down. Could I havde done something wrong when I replaced the thermal fuse?
thanks so much
  • Lori Price Feb 04, 2009
    Thank you so much! I went ahead and blew out the vent...and dried a load. The difference was amazing! I'll know to clean it out more often from now on!
    Sergeant:
  • 311 Answers
No the thermal fuse has nothing to do with that,although it will open again if too hot and that may be why it opened in the first place.most high heat ,long dry times are the house ducting.try this experiment.remove your dryer from the house ducting and dry a load[it wont hurt a thing]if not as hot,then get that ducting cleaned.if still hot then make sure the inner dryer air ways are clean.your blower is spinning fine[not broken on the shaft]and also check with ohm meter,or visually that your heating element is not shorted to ground[then it by passes the cycling thermostat.if all those things good and still getting high heat i may replace the cycling thermo.but as a repairman i did not have to do that very often.most of the time it was the other possibles. i hope this helps abit God bless ,tom
Posted on Feb 03, 2009
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Hello, my dryer MDE5500AYW won't dry on a cool temperature. It is an electric dryer
You buy no parts
You diagnose the problem
to find something wrong
How about looking in the owners manual
& follow the trouble chart
I do not know about Maytag Dryers, but the washers
have a diagnostic manual in a bag under the cabinet,
they don't want you to find,your dryer may also.
Nov 20, 2014 | Maytag MDE5500AYW Electric Dryer
Maytag neptune mde5500ayw chirping, buttons wont do anything. was told to replace control board. that did'nt help at all. any ideas?
The blower wheel on these tends to wallow out. That makes the dryer overheat and take twice as long to dry the clothes. Lint begins to build up in the filter housing. Finally the temp exceeds 350 and the round white fuse on the blower housing melts. Boom you has got a dead dryer. To get into the slopefront type dryer seems a bit intimidating bit really is not. Remove the door. The door is reverseable so 2 more screws opposide need to also be removed. Then the goalpost shaped front pops off. Then that reveals the top hold down straps. Remove them and top can be popped. Next you remove the front shroud the drum rides on. then get the drum out. Did I mention you do not work from the back at all on this model? Do not try to fix it in the wash room. Take it ouitside and put it on the picnic table or a tailgate to repair it. You will need a phillips head screwdrivers pliers 1/4 and 5/16 nutdriver and snapring pliers.
Shopvac to clean it up and probbaly a new fuse and blower wheel.
SERVICE MANUAL
Jul 31, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
387 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
