Question about Kenmore 42822 Front Load Washer
The machine show problem F 11
The washer start working fine after few min. mark F 11 and stop, but the door dosn't open, this problem start only in one cicles , and now is all cicles.
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Washer/dryer on spin fast but keeps stopping and starting how do I open the door?
If you sure that its not full of water, you should set the program to the stop position, and wait a few mins for the lock to release.
Jun 04, 2016 | Washing Machines
My friend has an xqg65-11 all in one that she bought used. It worked fine for a few weeks, then started to not move to the next cycle, it just stopped. She has been manually clicking it to the next cycle....
There is a lint filter right under your washer door. You push that lid open, and you will find the lint filter. I have the same machine. but min is an xqg50-11. Is that a washer/dryer combo?
Jul 20, 2011 | Haier XQG50-11 Front Load Washer / Dryer
My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
May 26, 2011 | Hoover HTC243 Top Load Washer
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Front door won't open on 2003 Kenmore Washer and no release
When I had the same issue I tried the following things. It has been so long I do not recall the exact order I did them in or what finally worked but it did open.
Unplugged it for 5 mins.
Turned off everything else in house.
Plugged it back in.
Pushed Drain/spin - start (I could hear it try to click locked)
Then I pushed to stop it (then I hear the door lock click)
I tried all the different wash options and finally one of them allowed me to cancel the wash and the door unlocked. I know I unplugged it at least twice because of the computer needing to be reset. When a tech was working on it a couple of years ago I had him explain a few things and I don't recall the exact # of min's you are supposed to wait so I use 5 min's.
The water was still in my washer and I had to open the bottom and drain it by opening the cleanout to the pump. Large mess on the floor. Make sure you unplug the machine first. It will get on the wiring.
I also learned recently that your house electrical needs to be correct. These machines are extremely picky about their power.
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Error message wont go away
unplug machine from mains for 5 mins then try it. close IRE
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 42822 Front Load Washer Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
