Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Hitachi 51F510 CONVERGENCE ISSUE
I just had the 2 IC`S replaced and the blue crt blinks on and off . It did this before the IC`S were replaced also. Any suggestions would be greatly appreciated as this TV is only four years old. Resistors were also checked.
  • Hitachi Master
  • 8,617 Answers
Check the Blue CRT drive board for defective solder joints especially at the CRT socket
Posted on Feb 04, 2009
My Hitachi 51f510 has no green adjustment. The lamp still works if i turn it up on the g2 block but I get lines across the screen that i dont get with the red and blue. I also cant see any text in green...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 11, 2011 | Hitachi 51F510 51" Rear Projection...
Hitachi projection TV - video is in 3d rainbow
This sounds like a convergence circuit problem. Your set has two convergence IC chips (integrated circuit). One is for the red CRT, the other is for the blue CRT. This is a common issue with projection TVs. It is not a difficult repair if you have any experience with electronics and soldering. Both convergence ICs should be replaced at the same time. The part is IC (STK394-160E) and is available for around $36 or less. If you have a shop fix this they will likely charge $300-$400. If this information was helpful or if you would like to know how to do this repair in more detail post back on this thread. I would be happy to walk you through it.
Dec 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
51f510 picture yellow issue blue lens appears to
First try advesting the screen controls for each CRT.
The problem cound be OVERHEATED COMPONENTS ON THE CRT PWBs
Any of the following components could cause this: Q805 Q855 Q8A5 Q804 Q854 Q8A4 R815 R865 R8C5 R813 R863 R8C3 R814 R864 R8C4.
You did not give much information to work with it may be time to call a TV Tech.
Jul 11, 2009 | Hitachi 51F510 51" Rear Projection...
Hitachi Television
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 18, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Getting double images on screen like outlines on images
Your TV has a failure of its convergence output ICs and perhaps some of the convergence circuit's other associated parts. The part numbers for the ICs are on the IC face. They can be purchased thru Hitachi or online at MCM Electronics.
Feb 10, 2009 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 Convergence Problem Solution???
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 09, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 43FDX15B Convergence Failed
You will need to order part no. CZ01341. This is the output ic. There are 2 of them, replaced them both. The numbers that are printed on the old part will not match the new part, do NOT take this to hart. It is a modification that you are putting in. You should be able to do this your self. I would charge 350.00. The set is not worth much, not working. Maybe 100.00
Jun 05, 2008 | Hitachi 51F510 51" Rear Projection...
Re: 43FDX01B blue convergence issues
Ditto CTF1800's comment....Check RP-41 1.5 ohm 2 watt and
other low value resistors near IC's mounted on large heatsinks.
STK392-110 original convergence IC's can be upgraded to
Hitachi # CZ 01341 new number STK394-160E for greater reliability.......Hitachi also has an IC / resistor kit # X480295,
but I don't change good resistors, only the bad one(s).
Practice good visual acuity technique and ask questions!.....T.
Jan 02, 2008 | Hitachi 43FDX01B TV
Hitachi 50+in rear projection tv
If you mean that the 3 colors (reg, green and blue) suddenly no longer line up properly in one area of the screen, it means that one of your convergence IC's has burned out and needs to be replaced. There is no adjustment that will correct the picture in this case. When I do a housecall to replace a burned out convergence IC and realign the convergence circuits, I charge $150 but shops in your area will vary so be sure to ask around.
Sep 18, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
