Question about Apple iMac G4 Desktop
G4 imac won't power up every time
Hi there
I have been a loyal lurker to the site for far too long. I now break my silence with a question!
I have an Apple iMac 700MHz 15" Flat Screen (now 1gb ram) (M8672LL/B). It consistently fails to power up.
I've replaced the PRAM battery. The problem prevailed. I replaced the cable. No luck. A Hardware Test ran overnight, nothing showed up. I re-installed. No help.
I cleared out the dust from the base with a hoover. It worked for a short while, then the problem came back. There is a clicking/tapping sound that can sometimes be heard from the base when it's plugged into the mains and isn't powering up. Resetting the Power Management Unit seems to help power up the mac, but it's never a permanent fix.
I'm all out of ideas! Does anyone have any ideas what could be the problem. I love this mac. It's part of the family - it's my baby! I know mac parts aren't cheap, but I really want to save this mac from the dump.
Any help is much appreciated!
Thanks for reading
Luke
  • soselective Feb 09, 2009
    Thank you Allanster
    I suspect you a right! I'm located in the UK though :-(
    Many thanks for the advice!
    Luke
Had a similar problem I'm working on right now for my G4 MDD. I had fixed the power on switch by resoldering it to the circuit board (that way the external button made good contact with the internal switch). It worked for two days till it had the problems you're describing. (Light goes on, some clicking, etc.) but no "ignition". Every time I reset the pmu, the external button would power up fine. My wife finally pointed out that I had stuck in a couple ram chip my friend gave me while I was working on the switch. I checked "about this mac" and realized both they failed the startup test. I took them out and the external button has worked the last dozen times I've used it. Keeping my fingers crossed...
Posted on Mar 03, 2009
    Scholar:
  • 60 Answers
Bummer, sounds like power supply. I used this guy when the logic board went out on my powerbook and it's been purring away for 18 months since. I spent days searching for cheapest parts and most reliable service and turns out he was both! Apple wanted $1200 for new board (no warranty) and he repaired with warranty for $350. You can check out the testimonials page if you're leery (like I was).
Posted on Feb 03, 2009
Mac g4 added more memory won't boot up
Possibly not twins, must be same chips.
remove insert old if not damaged and see it it reboots
May 17, 2013 | Apple iMac G4 Desktop
Printer won't work with new computer
You should visit the Epson site and download the latest drivers for the CX9400 and install
Jan 16, 2013 | EPSON Stylus CX9400Fax Series
Computer won't turn on
Resetting the iMac (Flat Panel) Power Management Unit (PMU...
http://support.apple.com/kb/ht1712
Read all of article, try other solutions first.
Dec 29, 2012 | Apple iMac G4 Desktop
Replacing hard drive
Hard to say without the model number. This site has guide for all the g4 iMacs http://www.ifixit.com/Device/iMac_G4
Oct 11, 2012 | Apple iMac G4 Desktop
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
Literally , how do you turn it on.
To turn iMac G4 on, find the power button which located on the back.
(see from the picture below, the button I marked with a Green Arrow)
Good luck :)
Apr 17, 2010 | Apple iMac G4 Desktop
Imac g4 dead
Hello, The power supply is part of the motherboard in the iMac G4, so it's hard to change it. The repair would certainly cost more than the price of your iMac. You can try to take off the small battery, and reboot it to see if it changes. To open the mac lay it down, screen on the table (on a t-shirt). Unscrew the four screws (they wont come out, so just unscrew them. Pull the screws and take off the silver plate. Then you'll have access to the inside. Good luck
Jun 12, 2009 | Apple iMac G4 Desktop
Thanks for the help!
That sounds like it would fix it. Have you recently updated the memory in the imac? It may be incompatable. Otherwise it may simply have become faulty over time.
Please make sure that before you open up your imac, you're not voiding your warrenty. I know that the aluminium imacs allow this, but i dont think the G4 versions do.
Hope this helps,
Nathan.
Apr 13, 2009 | Apple iMac G4 Desktop
Problem with Apple imac Power Supply
The most common problem with imac G4/800's are failing logic-boards. This will cause the mac to not power up at all giving the impression that the PSU is broken.
If however, you are indeed certain that the fault is with the power supply, they are available from many stores online
Power Supply for iMac G4 15" LCD (700 & 800 Mhz) 661-3184 614-0147
Dec 09, 2008 | Apple iMac G4 Desktop
MAC EMAC G4 & IMAC G5 power supplies
Is this a tower or Imac?
Is there a reason other then curiosity you need to know?
All power supplies have it labeled on them what they are if you need it.
Mar 26, 2008 | Apple eMac G4 Desktop
Apple iMac G4 Desktop Logo
461 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
