Question about Dell Inspiron 5160 Notebook
Dell Inspiron 5160 wont turn on
Hello my laptop seems to have stopped working.. When I plug the laptop on I get 2 green lights that come on but nothing else, no sounds.. Unpluged I have no lights.. Nothing happens when I push the power button.. What would one guess the problem is?
Thank you
  • Anonymous Feb 07, 2009
    My dell inspiron 5160 wont turn on but there is two lights that keep flashing.
I would suggest that first try running the psa test on ur system which could b done by press and hold FN key and power button together and leave it as soon as u see anything on the screen or any led in case u get any error code or beep sounds then it has to do with hardware and u ned to contact dell in case ur system is still under warranty.which lights do u see come up when u press the power button.I guess u r talking abt the led's for capslock , numlock and scroll lock.try reseating the memory module from the system and try running ur system on one memory chips and vise-versa because it seems that may b the prob is with the memory sticks.
in case u want manual for removing the memory sticks try using support.dell.com and u would get the manuals from there.
Posted on Feb 03, 2009
Dell Inspiron 5160 doesn't charge
you mite have fried the power supply. or the battery.. try removing the battery and pluging it in,and then power it up
Jun 13, 2012 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160. When plugged in then power light lights up (before hitting the power button like my 5150) and the battery light is amber. The 5160 will not do anything - not power on at all.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
May 26, 2011 | Dell Inspiron 5160 Notebook
Dell 5160 Won't start up or charge battery
I have the dell inspiron 5160 works great a little slow but no big deal. The problem I have as of Monday the power cord will not stay in and now will not charge. Is it the power port? Can this be fixed?
Jun 27, 2009 | Dell Inspiron 5160 Notebook
I have dell 5160 charging problem when I plug in just two green flushing not center one then no lights and no charging please let me know if someone has any solution.thx
pls check the batt is ur notebook working fine on ac power if yes then check ur battery may be it is not working properly and needs replacement
pls do rate me
Mar 07, 2009 | Dell Inspiron 5160 Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell 5160 orange light
removed battery, and acadapter FROM UNIT, HOLD DOWN THE POWER BUTTON 60 SECOND That should drain the power from it
Mar 26, 2008 | Dell Inspiron 5160 Notebook
Problem Dell Inpiron 5160
Hello Maciekpl,
This is Romeet,i would like to try and help you solve this, please let me know if you have a replacement motherboard for your laptop ready? also let me know how comfortable would you be with opening up the thing and replacing it?
B.Regds
Romeet
Dec 01, 2007 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Notebook Logo
355 people viewed this question
Alun Cox
