Question about Panasonic Lands Phones
Excessive static on the line
I've had my model KX-TGA931 T for several weeks, and from the beginning I get major static on the line when I'm on a call. It's almost impossible to hold a conversation over the static. Is there anything I can do to fix this? Are there other channels available that I could switch to? Thanks for your help.
  • ladybon Feb 04, 2009
    Thanks for those great ideas. However, I've tried all those things and none of them worked. I can't figure out what the problem could be! I do have DSL, but have filters on the phone lines.
    Problem Solver:
  • 13 Answers
Try turning the phone on then off. then if that doesn't fix it try touching the phone to discharge static buildup.
Posted on Feb 04, 2009
  • andrewimeson Feb 04, 2009
    Perhaps the phone line is loose in the phone or the wall?
Mitel Superset 420 corded phone has static
Static on the handset of a MITEL phone is indicative of either a defective handset cord **OR** the user has one of those cord detangler devices attached to the cord. If it's a cord detangler, remove it, smash it with a hammer and throw it away. Advise the end-user to please not use these as they all become staticky after several weeks use. If the user has problems with their handset cord constantly becoming tangled, THAT PROBLEM is indicative of neck or ear fatigue from frequent LONG CALLS and the user keeps moving the handset from one ear to another (changing hands). THE FIX FOR THIS is to give the user either a corded or cordless headset (or check SMDR records for excessive personal calls)
Feb 12, 2014 | Mitel Superset 420 Corded Phone
I have a Panasonic PNLC 1012 phone system - i want to be able to use the pin to stop my daughter from phoning out - i know how to block in-coming -i is there a way of stopping her from making calls without...
Thanks for visiting FixYa!
I believe the number you've provided may be the part number to the charging base which the phone sits in. Check to make sure. Panasonic phones that use this base (usually) begin with the letters KX-TG
You may have a KX-TG8521 or a KX-TG8523. Again, please verify the exact phone model you have then re-post a NEW question with the correct phone model. Thanks!
Jun 27, 2011 | Panasonic Lands Phones
I am getting static on all handsets. What can I do to stop it?
sounds like it may be your phone lines or loose connection at the base station. buy a cheap hardwire phone to test this if the new phone has static it is your phone lines. if it doesn't have static check the connection to the base station.
Mar 12, 2010 | Panasonic KX-TG9341T Cordless Phone
Kepad beeping while using MagicJack
I have the same problem with the key pad beep during telephone
conversations and I hace a Uniden 5.8ghz phone.
So its not just panasonic 5.8 ghz phones that do the beeping.
Jul 11, 2009 | Panasonic Lands Phones
Static on my pair of Uniden cordless phones (Model DECT1560)
Is your base near a computer or other electronics? Also, make sure your microwave is not on. I get static if I do any of those things.
Jun 20, 2009 | Uniden Cordless Phone
Static on line
Does the static stay on the line after the called party answers?Is the static on incoming and outgoing calls on any phone?if the answer is yes to the above questions,check your house jacks for corrosion.There are a number of things that can cause static inside your house and outside.From the interface box on your house where the wires come from a pole or from under ground is phone company problem.From the box into the house is your problem,so the easy solution is to make the phone company come out and determine from what side the static is coming from.There is usually no charge for this unless you have them come into your house if the problem is there.
tk46
Jul 20, 2008 | Panasonic KX-TG1033S Cordless Phone
Static on my phones
Is the "static" actually the DSL on the other line? If the separate lines are run close together, some crosstalk can be experienced. Try fitting a DSL filter to your 'phone, if this stops it, that is the problem. What you do from there is up to you, but if a simple filter fixes the problem, why worry?
If the "static" is still there when a filter is used, it obviously is something else. Try a different 'phone on the line, 1 'phone only, if there are more than 1 or a computer or fax machine on the line. If it is still present, you may need investigation by your provider.
Apr 30, 2008 | Panasonic KX-TS4300B Phone
Incoming calls loaded with static and I cannot hear them clearly
Try connecting line 2 where 1 is connected. If there is no static it is youre system ie phone itself. If there is static there is definately a problem with youre line. Static can usually be attributed to old lines that the moisture barrier has been compramised. If the line is under youre house or in the walls you may have to pay for it. But if it is the companys line it is their issue.
Mar 26, 2008 | Panasonic KX-TG6700 Phone
Lots of static & noise during calls
First, do you have any other phones? Have you eliminated the phone line itself as the problem?
If there are sound problems in multiple cordless phones and the problem is not in the wiring or the line, than the base unit is transmitting a poor quality signal. Try tapping the base unit to see if the problem changes any... light taps up to a typical knocking on a door strength taps are all that should be necessary.
Dec 06, 2007 | Panasonic KX-TG5632 Phone
Lands Phones Logo
385 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
