Question about Epson ACULASER CX11NF All-In-One Printer
Stripe down page!!
Cx11NF produces stripe down right side page which goes away after cleaning with cleaning stick then comes back after 4-5 pages (1" wide)
Changed toners carts and PCU. Help somebody please!!!
  • 1 more comment
  • DocLonny Feb 07, 2009
    The stripe is actually blank! The print that appears in the area becomes lighter with each page printed eventually becoming a 1" wide blank stripe down the right side of the page.
  • DocLonny Feb 10, 2009
    Tried all the above without success. Still need some help.
  • epsinopin
    epsinopin May 11, 2010
    Is your 1" stripe black or a color. If a color, what color ?
    Thanks !
    Problem Solver:
  • 9 Answers
Thanks for the clarification.
The "Cleaning Stick" is actually a little pad on the end of a flexible piece of plastic that wipes off the glass that covers the Laser.
Tip: When you are using it, you should apply a slight upward pressure on the end you are pulling and pushing. This forces the pad down onto the glass and will give better results. The little plastic rods that are attached to the pad are very flexible and should not break with the slight upward pressure.
Now for the actual problem:
You are getting the glass clean with the pad but it isn't staying clean.
The reason for this is that Toner (Black, Yellow, Cyan or Magenta) is drifting down from up above.
The usual cause for this (with the CX11) is that one or more of the Toner Cartridges are not inserted properly or that they were inserted properly but have popped loose.
I suggest that you check ALL toner cartridges.
It would be best to Remove and Re-insert them.
No need to completely remove the cartridges from the "drum".
Just pull them out slightly then re-insert them properly.
Make sure that you follow the Manual Instructions to the letter !
I have seen some so-called "experts" remove/insert them improperly !
Good Luck !
Posted on Feb 08, 2009
  • epsinopin
    epsinopin Feb 12, 2009
    I'm going to make three assumptions:
    1. You correctly removed & re-inserted ALL 4 cartridges.
    2. Your problem is still the same one. That is, after you clean with the Wiper, the prints are ok for several copies then the blank streak begins to appear.
    3. Your printer is out of warranty.
    If the above assumptions are correct then there are two Choices at this stage.
    1. "Dive deeper" into the innards of the CX11 to find out more.
    or
    2. Call for a qualified Epson repair person.
    If you want to "go deep" AND you are proficient with basic tools (Have at least a good #2 Phillips screwdriver, a good flat blade screwdriver and a good pair of needle nose pliers.) then maybe we can find more about out what is causing the problem.
    BUT...
    Please understand that you could actually cause MORE & possibly irreparable damage to your printer if you inadvertantly push or pull something too hard during the disassembly or re-assembly.
    If, after all my ranting above, you still want to go ahead then respond back and I'll attempt to guide you through some disassembly.
    Thanks !
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
Occasional 1/2 inch wide vertical column of color printing on page
Yes absolutely the PCU problem, contact your nearest shop to check the PCU before anything will happen to your printer.
Please rate me solved you decide to check the PCU. Don't look for another solution because I got already the right answer which already suspected at your own guest.
Best regards,
Philip
Nov 12, 2007 | Epson ACULASER CX11NF All-In-One Printer
Right side of every page has pink strip down page
Either your magenta cartridge is leaking out of the right corner or you have a defective magenta drum.
(maybe it got scratched when changing the cartridge?) If it's the magenta drum, you have to replace all the drums since they come in one unit. OEM part only.
Nov 20, 2009 | Brother MFC-9840CDW Laser Printer
Intermittent blank stripe down Right Side of page
Open the top cover, lift up the PCU lever & remove the PCU. Rotate the carousel (Toner holder) by hand and check that all of the toner levers are locked down fully. Check if any of the toner levers are loose and possibly moving as the drum is rotated. There is a small clear plastic flap below each cartridge, it is possible that one is fitted incorrectly or even missing allowing toner to leak past and fall on to the laser lens thereby blocking the laser and causing these symptoms. Hope this helps.
Feb 02, 2009 | Epson ACULASER CX11NF All-In-One Printer
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
White scratches and a "breaking" mark on printout
Epson CX11NF printer problem-repair solved
To clear stripe....Open the front cover and look on the inside of the right side of the printer....There you will see a pictorial instruction showing the PRINTER HEAD cleaning procedures.
Follow them (remove tab/plug on right side, pull out on head lock arm on inside right, then fully pull out the printer head arm inside the port on the (outside of printer) right side.....Then push it back in, replace tab cover, push the lock back in (inside right-front) and problem solved.....
God Bless,
Happy Epson CX11NF User
Oct 14, 2008 | Epson ACULASER CX11NF All-In-One Printer
Light stripe down right side of colour print out
I had the same problem and managed to clear it by cleaning the print head. You can fiind instructions on how to do this in the pdf manual on the Epson web site at ftp://download.epson-europe.com/pub/download/314/epson31436eu.pdf - go to page 351 and it should get you through it OK.
Nigel
May 08, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printing problems
According to the manual, "If there are white vertical lines on your printout, you will need to clean the print head."
I had that problem and cleaning the print head solved it.
Mar 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
422 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
