Question about HP Color LaserJet 8550n Printer
CLJ8550n poor print quality and wrinkled paper
We have a CLJ8550n printer. When we print from the tray used for tabloid size paper it wrinkles the page. Is there something I can do to try to fix this before ordering a new tray?
The print quality is very poor. There smudges and streaks as well as white blotches where there should be color.
    Scholar:
  • 96 Answers
This is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Posted on Nov 30, 2009
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
May 14, 2014 | Kyocera Office Equipment & Supplies
Envelope printing error - envelope prints wrinkled from MP tray
sorry buddy but mfps wrinkle envelopes he have tried many things on many models they all wrinkle the best thing you can do is try to reduce the wrinkle we tuck the flap inside and that helps a little other than that sorry
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
Paper wrinkles when printing
You can try these following solutions:
If the paper does not completely eject, press the paper with folded side paper button, then open the printer cover and remove the paper. Also, check the Paper Size setting in your application or printer software.
If the paper is wrinkled when it comes out, it may be damp or too thin. Load a new stack then try to print again. You can also try to check the printer alignment and the printer setting.
Feb 11, 2010 | Office Equipment & Supplies
My printer wrinkled the paper when it is out
Try using fresh paper from a new ****. If still wrinkles might be an issue with your fuser. The fuser is the part that heats the toner onto the paper and if the paper contains too much moisture content (from improper storage methods), this can cause wrinkling effect as well.
Try printing with different types of paper and from manual tray to isolate problem. If it occurs all the time, most likely bad paper or bad fuser.
Jan 16, 2010 | HP LaserJet 4200 Printer
False empty paper tray message
Dude,
If an“Out of Paper” message is shown on your computer and your printer cannot pick up paper, then follow the steps below (in the order) to resolve the problem.
Step 1:Checking the media and print settings:
  1. Remove power cord when the printer is ON, wait a while and then plug it back.
  2. Turn the printer ON.
  3. Place a Paper, which is not ripped, dusty, wrinkled, or bent.
  4. Place the papers of same size.
  5. Tap the stack of the paper.
  6. Verify the stack of paper between 10 to 25 sheets.
  7. Insert the stack of papers into the printer.
  8. Set the paper settings in the print driver.
    • Open a Document in the application, which has to be printed.
    • Click File > Print > Properties > Paper/ Quality tab.
    • In the Size Drop down menu, Select the Size of Paper.
    • In the Type Drop down menu, select Type of Paper.
    • Click OK.
  9. In the Print Dialog box, click OK to print .
  10. Try printing again.
    Note: If this step resolved your problem and you want to print on another media, change the paper in the unit, repeat steps 2 to 7 above for the new media.
this will solve your problem
Dec 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp 8000n wrinkling paper
question if you are using plain paper and it wrinkles, but you can print with high quality 100gsm paper
answer the fuser could be on the way out or damaged
Nov 13, 2008 | HP Office Equipment & Supplies
HP Color LaserJet 8550n Printer Logo
545 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
