Question about Logitech Harmony 880 LCD Remote Control
Challenging Charging I love my remote, except for one major quirk. The remote won't charge in the cradle unless there is roughly three pounds of pressure forcing it to seat properly. I've already sent in to, and received a replacement from, Logitech. The replacement remote is exhibiting the same behavior which leads me to believe there may have been a flaw in the manufacturing process, if not one inherent in the design. Right now I just rest a little weight on it once a week to make sure it gets a full charge. I use one of the satellite speakers from my home theater kit. Anyone else have this problem? Anyone with this problem have a better solution?
  • Yoyodyne Propulsion Systems
    I'll check it out when I get home. Thanks for the response!
This happened with mine. The problem is that the battery is not making a firm enough connection with the prongs. To fix it simply fold a small piece of paper about the size of a tic tac and slide it between the bottom of the battery and the bottom edge of the battery compartment. This will push up the battery against the prongs. It sounds crazy, but it will work. I've had my remote for over 1 year...same little piece of paper has done the job.
Posted on Feb 20, 2009
The first thing to try is Open the base unit and bend the three pronges so they protrude out farther and evenly. I had the same problem and this resolved the issue. The Base unit is very easy to open with screws on the bottom and it is easy to adjust the 3 pronges.
Posted on Feb 05, 2009
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
I need replacement remote charger (part #5-2582) for my GE 2.4GHz speakerphone and answering system # 27958.
I love my old GE coded/cordless phone set, but the cordless phone's buttons won't dial anymore; they get stuck. Can I get a replacement for the cordless phone only? The charging cradle seems to still work. It is Model # 27958GE1 A. Thanks!
Dec 14, 2010 | Uniden Cordless Phone
My one year old Logitech Harmony 890 is not charging the battery. I have replaced the battery and watched it drop from full charge to 1/4 charge about 2 days. I have verified there is 8.5V at the pins in...
Generally there are three possibilities (apart from the battery going bad) that can cause your remote not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts slightly farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you want to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together. Good Luck!!
Feb 26, 2010 | Logitech Harmony 890 LCD Remote Control
Battery will not recharge. Completely dead. Do I
Are you sure it's the battery and not the charging cradle? Make sure you try some of the following before you buy another battery. If it ends up you do need another one, you can pick up an OEM battery on Ebay for around $10. Just be careful that you get a battery that will charge in the cradle. There are some knockoffs from China that will ONLY charge using a special wall charger, so read the ads carefully.
Generally there are three possibilities (apart from the battery going bad) that can cause your battery not to charge:
Feb 12, 2010 | Logitech Harmony 890 LCD Remote Control
I have a 880 per the box and it will not charge all the way.
I'm not sure I understand your question completely, but if you are having a charging problem, read the following. You may find something helpful
Feb 05, 2010 | Logitech Harmony 890 LCD Remote Control
My harmony 890 remote stopped working; wouldn't
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear additional beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
Dec 16, 2009 | Logitech Harmony 890 Universal Remote
My harmony 880 will not charge
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show2_bing.gif should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). Opening the remote and checking to make sure that the plug is completely seated is another thing to check if all else fails.
Dec 02, 2009 | Logitech Harmony 880 LCD Remote Control
Remote is not recharging when placed in cradle even after cleaning posts with alcohol.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with something more 'high test' than alcohol - a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
Nov 21, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 880 not charging in cradle it's there all nite and in the morn it still only has 1 bar
Oct 18, 2009 | Logitech Harmony One Advanced Universal...
My remote wont charge? even on charger - it says
Sep 30, 2009 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 880 LCD Remote Control Logo
119 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
