Question about Emerson EWF2703 27" TV
I need a remote code for an emerson ewf2703 27 inch flat screen
I need the remote code for an emerson ewf2703 27 inch flat screen to program my direct network remote to my tv
  • zsdfg dfg Mar 25, 2009
    My remote finally gave out and I have tried two universal remotes and hundreds of codes, to no avail!!!!!
    I have to be able to push the "game" button, otherwise known as "input" in order to watch movies and play games.
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
Posted on May 06, 2008
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
  • 86 Answers
SOURCE: Need TV code for Emerson HDTV LC320EM8A
I was successful in finding codes on this site that were not listed in the manual:
Direct TV Remote Codes
Posted on Feb 07, 2009
rulds2008
  • 3866 Answers
SOURCE: my 27 inch emerson flat tube tv only shows the
You will need to replace the Horizontal IC around $80 bucks for the parts and labor. What happen here is when the Horzontal ic gives out the screen basically folds to the middle. Do not shoot the messanger here but have the TV looked at by a professional locally.
I hope this was Very Helpful to you today please leave your feedback and ratings.
Posted on Dec 07, 2009
Testimonial: "great feedback thanks"
Hwhat is the code to program it to an Emerson 32 in flat screen TV
Stacy, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-emerson-tvs
http://www.remotecodelist.com/remotes/emerson/emerson.html
What is the remote code for an Emerson TV
Mar 25, 2016 | Emerson Televison & Video
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Change the resolution on my emerson flat panel television
You need the remote.
You can buy replacement remotes.
Mar 26, 2014 | Emerson Televison & Video
Cannot program direct tv remote to turn tv off/on or sound up/down
called funai, gave me number to call emerson. emerson said they give codes to direct tv., call them. called direct tv. said they have 12 codes, they would give me codes, the rest is up to me. none of the 12 codes worked. stuck with using 2 remotes. bummer!!!!!!!!!!!!
Nov 30, 2009 | Emerson Televison & Video
Emerson 42 inch plasma (Walmart special) need code
Try the Samsung codes that are in the manual for the remote. The Emerson is a rebadge of a Samsung. My Dish remote worked poorly with the Emerson codes but the first Samsung code I tried worked beautifully! :)
Nov 28, 2009 | Emerson Televison & Video
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Feb 18, 2009 | Emerson Televison & Video
Need TV code for Emerson HDTV LC320EM8A need code to program my direct tv remote
Feb 07, 2009 | Emerson LC195EM9 19 in. LCD TV
Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Jan 04, 2009 | Televison & Video
Remote Code for Emerson LC200EM8 LCD HDTV 20 inch
sony RM-VL600 remote, can be programmed remote to remote...I bought it, it works.
Dec 29, 2007 | Televison & Video
Emerson EWF2703 27" TV Logo
954 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
