Question about Dell XPS M2010 Notebook
Dell xps 2010m display corruption and then lock up - what causes
My laptop has started to pixilate, if that is the right term, areasof the screen have lines or dots and just after that you can bet the thing will lock up.
I am guessing its overheating but the fan works - could it be graphics card memory?
Also I noted an earlier post said they had replaced the graphics card - how is this done and where do you get one from?
Kev
  • kevin_hewits Feb 04, 2009
    Thanks for the approach - have done this. The refreshrate is 60 and latest drivers installed. Used it today without the power adapter - just on the battery and it behaved - until the battery gave out (45min) I then plugged in the power and and continued to use it, after about 5 minutes it shut down without any warning. Could this be a case of overheating - I am sure the fan is OK but do not know how to get to it - or anything else after removing the cover for the RAM. Kev
  • Naterjunk Apr 20, 2009
    Lines occur across applications, pixels are off colors on startup screens. Have gotten overheat restarts in the past, but added an external cooler. Believe the issue lies with the video card and probably its fan - just wanted more evidence before I start buying replacements.
    Kev - you can eBay the video card, or google xps m2010 video card and pick the retailer you prefer.
  • 679 Answers
Lets see what card is in there, it might be as simple as a driver or the refresh rate may be set to high. See what the refresh rate is set to, step it down to 60 and lets see what happens. I am Gymowner for the sake of communicating because we aren't in a live chat, I may lose you, so at least lets be sure we both can find each other Kevin, ok try tyat first, then get the latest driver for your card. My wife and I are both gamers, so I have had this problem myself, and I want to eliminate the card first
Posted on Feb 03, 2009
Dell XPS M1210 Stuck on blue screen due to hard drive
To determine if your hard drive is bad or good, run the Dell diagnostics.
Here is a link for the owner's manual of your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1210_owner%27s%20manual_en-us.pdf
Feb 08, 2013 | Dell XPS M1210 Notebook
Starting Windows
In that case, I would reinstall Windows. Something must corrupted in windows. Do you have your OEM Windows disk with you?
Sep 06, 2012 | Dell XPS M1530 Laptop
Shadow bands on laptop screen
The backlight behind the display may be starting to fail, hook a spare monitor to the video output usually on the back, if okay! the problem is in the the laptop display, Now if both show the same symptoms, it is the Video Graphics Card normally built into the motherboard.
Apr 01, 2012 | Dell XPS M1530 Laptop
I have a dell xps m140, when I turn on the computer I get a blue screen with the message, STOP: c000021a {FATAL SYSTEM ERROR} the windows logon process system process terminated unexpectedy without...
Hi
You do not say which operating system you are using.
A blue screen can have many causes, so you need to undertake an elimination process to identify the cause.
Most importantly, do not repeatedly keep trying to boot if blue screen keeps appearing, as this could lead to hasrdware failure. It is important to identify and fix the fault as soon as possible.
If you read the full error message, there will usually be an indication of the likely cause of the crash as well as some suggested remedies.
Typical causes are:
Conflict with newly installed software
Driver conflict or corruption
Malware infection
Insufficient Hard Drive space
Operating system corruption
Hard Drive fault
Overheating
Memory corruption
Graphics card fault
Each of these will have a different remedy.
Start by studying the error message in more detail, try the suggested remedy options, then post again with more specific information, if necessary.
Hope this helps.
Aug 22, 2011 | Dell Inspiron XPS M140 Notebook
Screen is very dark, external screen displays desktop. what could have cause this problem? XPS Laptop M140 with integrated Video Card, replacing mb is not an option. Could it be bad video cable or...
The inverter handles how bright the display is because it takes the DC power from the adapter and converts it to high voltage AC power for the backlight. When the inverter starts to and finally fails, the screen goes dark. Your problem is most likely an inverter failure.
Jan 04, 2010 | Dell Inspiron XPS M140 Notebook
Dell XPS M140. No Sound. Checked lighted button,
Make sure any programs that consist of sound for example " Soundman" is running this can cause a conflict with your audio. Check for updates if you can
Jul 30, 2009 | Dell Inspiron XPS M140 Notebook
Screen remains black
It seems to be the screen of the system has gone bad , but in case if you see DELL on start of the system, it can be OS which is corrupted but the way you are telling that you can see it on external display it it the Monitor.
Good Luck
May 07, 2009 | Dell XPS M1730 Laptop
Dell xps,no video output and it sows only white backgrounds
hi good day,
on this situation the best way you need to do is to reformat and reprogram the laptop...
Feb 15, 2009 | Dell XPS M1530 Notebook
Dell XPS M2010 Notebook Logo
224 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
