Question about Zebra Stripe S600 Thermal Label Printer
Labels are printing off line. First one will be a little off, the second will be more offline. By the time the printer has printed about 5 labels, the print isn't on the label anymore. Uses T L Ashford software. Any ideas?
  • Stephen Clouthier
    Stephen Clouthier May 11, 2010
    How familiar are you with this type of printer? I support these for 500 clients averaging 20-30 each site so I know quite a bit & could surely assist you but I need to know your relative experience with them first.
  • 13 Answers
Ok so look at this. it should be clear.
Posted on Feb 05, 2009
Printer won't work says it is paused
Check your settings , & unpause it !
Mar 17, 2015 | Office Equipment & Supplies
Label is printed fine but each printed label print blank line before label print
To isolate problem run a test label from printer.Does the same thing happen? If so it is a printer problem.If not the problem is in the document itself.
Apr 24, 2014 | Zebra LP 2844 Thermal Printer
I want to print a label with two lines of print on it. How do I do it?
To create a two-line label 1. Type the text for the first line and press INSERT. 2. Use the arrow keys to select Second Line and press . A multiline symbol is inserted at the end of the first line, but will not print on the label. 3. Type the text for the second line.
Here's the manual, see page 12 - http://www.dymo-label-printers.co.uk/downloads/LetraTAG-LT100H-Manual.pdf
Jul 14, 2011 | Dymo LetraTAG Thermal Label Printer
The machine prints about 12 labels and then prints about 25 empty ones, prints 12 and the pattern repeats. Restarted the computer three times and restarted the printer five times, nothing helped.
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Feb 18, 2011 | Datamax DMX-I-4208 Label Printer
The Monarch 9403 does not print out multiples of labels continuously, it stops between each single label. Can you help? Cheers Debbie
Debbie,
I may need a little more information.
If you are using a 3rd part software application like that from Loftware, you may need to create your labels in such a manner that the print module prints strips of labels, and in the quantity that you need. Then the printer should produce the quantity each time you go to print.
If you are using a 3rd party driver, like that from Seagull Scientific, then you need to tell it to print that quantity, just like you would when printing something on your inkjet printer.
If you are sending the printer's native language directly to the printer, there is something called the format header. It looks something like this:
{B,1,N,1|
The second 1, is the quantity of labels. So if you want it to print 5, you need to change it to something like...
{B,1,N,5|
If neither of these make sense, please provide some additional details so that I may provide further assistance.
Jun 25, 2010 | Paxar Monarch 9403 Thermal Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
My Monarch 9416 203 DPI prints offline
You did not say whether this printer is the same as your others, if it is not then you will have to get the correct software driver for this particular printer.
Jan 08, 2009 | Monarch 9416 (Part M09416-TT04) Printer
Brother 640 printer says it is offline
Check the front control panel, and there should be a button that is labeled 'on line' or similar. Press it to bring the printer to an on line state.
Sep 01, 2008 | Brother MFC-640CW All-In-One InkJet...
Not printing on whole label
Mine was doing this until I followed the steps to recalibrate it. Sometimes it goes back to printing incorrectly and I just recalibrate it again.
Feb 12, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
154 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
