Question about ASUS EN7600GT/2DHT/256 (256 MB) PCI Express Graphic Card
Vertical lines at BIOS splash screen
Hello, I've looked through your archives and my problem is very simlar to http://www.fixya.com/support/t398635-dunno_whats_problem
My graphics card had power running to it and the fan was spinning, and Device Manager failed to see any problems. My harddrive seemed fine but it wouldn't boot windows on my main desktop (just like the problem in the above post) and the BIOS splash screen on my main desktop was graphically distorted with vertical lines. I tried to boot XP from that harddrive in a different computer and it froze also.
So I repartitioned and reformated the HD as advised in that previous post, and things seemed ok. However, the BIOS splash screen still showed verticle distortion.
My motherboard is an ASUS M2N SLI Deluxe, gfx card is an ASUS EN7600GT. I downloaded the latest non-beta BIOS from ASUS and the latest chipset drivers. After installing the chipset drivers and nForce stuff, I just tried to flash the BIO with the latest version of ASUS's BIOS update. The "Erase ROM" proceedure worked, as did "Flash ROM", but "Verify ROM" failed at about 86% and the system has crashed when I asked it to retry.
I've never lost a BIOS before, is it a "Time to buy a new motherboard" situation? Also, does it sound like the BIOS or motherboard was at fault, or could it be my GPU or graphics card memory also?
Thanks very much Experts!
  • 2 more comments
  • themandontgi Feb 04, 2009
    Hey SubliMation, thanks very much for your response.
    I have a Gamestream OCZ 700watt PSU. Since posting I remembered that I have had a similar problem once and you can take the small round battery out of the motherboard and disconnect it from power for half an hour or so.
    The motherboard reinstated an old BIOS from a rom it had somewhere so I'm back to the point of having Windows XP working with no graphics distortions so far (though I've yet to try running anything gfx heavy).
    I still have vertical lines appear both on the BIOS splash screen and on the black XP loading screen (rows and columns of 4 verticle dotted lines). Something I can put up with, but it seems indicitave of a larger problem with the gfx card or motherboard or whatever else. I don't know enough to make an educated guess.
    Thanks for the reply Buschchris1 :)
    I think my PSU is ok, but I disconnected my 2ndary HD, the soundblaster, the Plextor, and the old floppy drive and 56k modem. It didn't make a difference though.
    I'd already reset the BIOS and reseated the card but I didn't think to try the 2nd PCI-E slot. That didn't work either though.
    After reformatting I was using XP in 640x480 without drivers for the gfx card. When I installed them, XP wouldn't load, same problem as before. I uninstalled the drivers and tried it again a couple times and same result.
    My gfx card was about 2 years old. I expected it to last longer but I guess not. Does this seem to be a common thing with people running graphics-heavy programs? Should I have had a better PSU?
    Thanks very much Busch and Subli :)
  • Peter Steiert
    Peter Steiert May 11, 2010
    I'm the same way themandontgi, I don't really know what the problem could be. You definitely have the power to run the system, the only problem I can think of is that your PCIe x16 slot has some dust in it causing some of the lines on the BIOS and XP loading screens. However that's a real long-shot. It could also be the motherboard as you suggested, with some sort or manufacturing defect. Those tend to happen every now and then.
    Sorry I can't help you that much. I simply don't have any ideas about the issue. :-\
  • Peter Steiert
    What type of PSU do you have? Perhaps it went weird and messed up your motherboard causing the screen abnormalities while looking at the BIOS options.
    I don't think you're going to have much luck getting your motherboard to boot after the failed BIOS flash. Not real certain as I've never had to deal with it, yet from what I've heard I don't think you can boot from a motherboard (or re-flash the BIOS of the motherboard) which powered down while you were flashing the BIOS.
    If it turns out to be as I said, you can send the motherboard back to ASUS and ask them to change out the BIOS ROM chip. Depending on if you're still under warranty or not, you might have to pay a small fee.
    Master:
  • 474 Answers
Is your power supply rated to hand the board and the graphics card and all the other hardware?
Did the issue star with the video card?
try removing the extras like the CD drive and any other PCI devices and just putting the graphics card in and whats needed to boot the computer.
Also, reseat the graphiocs card.
also try installing just the drivers for the video card without any of the over clock software.
Try resetting your BIOS by disconnecting the power cabel and removing the BIOS battery and waiting a minute, put back in and restart/
Posted on Feb 04, 2009
Thin vertical blue ink bleed line from bottom of Malaprop screen - Fades over time
Yes, it's a screen problem. It could be a loose connection of the LCD and the motherboard or the lid lights gone bad. You can fix that by either resetting the connection of the screen and the motherboard or replacing the whole screen. You would need a technician to do that.
David
May 27, 2013 | HP Pavilion Computers & Internet
WHITE SCREEN ON SAMSUNG LAPTOP
Prior to the Windows splash screen do you see graphical issues ( black background, white writing, or bios splash screen) if you don't then the problem is with windows and will need to be reinstalled. Samsung ship laptops with a windows cd and is a fairly basic wizard. If you don't know how to do this google is full of guides. If you however see graphical problems right from turning the laptop on then there is likely to be a hardware fault straight from the factory. Contact Samsung and they will repair / replace the laptop through warranty. I have seen several Samsung laptops brand new from the box do this and It turned out to be a hardware issue and was replaced on warranty. Good luck.
Apr 17, 2013 | Computers & Internet
Once I turn on the laptop it stays stuck on the LG Splash screen, I press F2 to enter bios setup but it just stays on the splash screen, and nothing progresses, I can't do anything,
I've seen issues like this with a bad hard drive. When entering the bios it queries the hard drive first and it's got issues it can hang it up like this. If you have a spare try that. You can try to boot it without a hard drive to see if it gets past this. Some computers won't boot without a hd though. If you've got another computer you can look around online to make a flash drive bootable and use that instead of your hard drive. Lastly, get a new hd.
Oct 22, 2012 | Computers & Internet
Install english Windows XP on Japanese Panasonic CF-Y7. Simply insert OS CD and reboot does not help. Computer does not read CD.
The BIOS is probably configured to look for a bootable operating system on the hard drive before it looks at the CD drive. When you first turn on the computer, you have to hit a particular key to enter the BIOS setup (I don't know what it is for your model, but for most of the Japanese models I've seen it's the delete key. The startup splash screen should tell you what key it is. You have to hit the key before the splash screen goes away, otherwise it's already booting up from the hard drive.
Once you get into the BIOS, you can select the boot option page and move the CD drive up above the hard drive in boot priority. If the OS is in the Japanese language, the BIOS text may also be in Japanese. You can probably download an English-language BIOS firmware update to change that.
Oct 22, 2011 | Panasonic Toughbook y7 Notebook
One vertical line on left side of toshiba satelite pro L450 LCD screen
Lines on the screen can be pretty much a hardware (LCD) issue. The first thing to do is to check if this vertical line is present outside of the Operating System so you need to go the BIOS screen of your L450.
How to go to BIOS? : Turn on your computer and start hitting the "del" key repeatedly until you see the BIOS screen.
From there, observe your screen and see if the vertical line is present. If it is, then you need to take your laptop to an authorized service provider (Toshiba) near you and have the LCD of your notebook replaced.
In case the line is not present in BIOS, then a display driver reinstallation using your Toshiba driver disc can resolve this problem. Ultimately, you may need to reinstall the entire Operating system if this still fails to resolve the problem.
All the best, and Thanks for using FixYa.
Feb 19, 2011 | Toshiba Computers & Internet
With my old bulb I recently had black vertical lines. I just put in a new bulb and now the lines multi-colored. How do I get rid of the lines? This problem shows up from my TV and DVD feeds.
reset the settings to factory default. if you don't get the lines on the splash screen when you first start it up, try swapping cables. if that doesn't work or you do get the lines on the splash screen, you have a video processor chip issue. replace the main board.
Mar 18, 2010 | InFocus ScreenPlay 7205 Multimedia...
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Screen frozen with vertical lines
same problem
if anyone has any suggestions, it would be appreciated.
Nov 18, 2007 | Dell Axim X30 Pocket PC
ASUS EN7600GT/2DHT/256 (256 MB) PCI Express Graphic Card Logo
3,714 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
