Question about ACCO Brands Water Heaters
Combi Boiler pressure gauge reading 0, and radiator half on!
Our Baxi Combi boiler pressure gauge is reading 0. It goes up to 0.5 if hot tap used but always on 0, how can we try and fix? Also which may be connected, a radiator upstairs is only heating up the bottom half. We've tried bleading it, but the air comes out, stops like none is left, and that is it. No water spurts out. Any help on this would be great!!
P.S The product is a Baxi Combi Bolier 24, but wasn't listed below.
  • 247 Answers
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
Posted on Feb 03, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Baxi boiler 80E low pressure on boiler how to fix it?
Silver flex hose may be the (correct) filling loop. There may be a valve at each end of it, maybe just one at one end.
Open the single valve slowly and LISTEN for the sound of water entering the system, and LOOK for signs of the pressure gauge rising.
On the dual valve version open the first, then open the second slowly as above. Close both valves when pressure is adequate. Adequate is determined by the specifics of your system, but note that more pressure DOES NOT mean better showers, etc.
It should only take a few seconds to top-up, any longer indicates a significant loss of fluid from the system.
Jan 28, 2013 | Water Heaters
Pressure gauge reading zero
Hello Mark
First of all turn on a hot water tap and keep it running whilst you check to see if your boiler is firing up, if it is not then try to restart it, you should hear the flame if its running, turn your tap off then just stand by the boiler for a few minutes to see if the pressure gauge starts to rise, if it doesn't rise you will never get any hot water, you will have to add some pressure to about 1 and a half on the dial, to do that is simply turn on the water valve in the bottom of your boiler and watch your pressure gauge rise to about 1 and a half then firmly turn it off again, it looks like a small tap like the one at the back of your washing machine pipe, it's ok you will hear the water rushing in, now with your gauge at about 1 and a half and your boiler running your water will get hot
Oct 23, 2012 | Water Heaters
How do i fix problem E119 on a baxi duotec combi 24HE - boiler won't light because of lack of pressure but I have no manual to assist me as the instructions on the boiler says.,28,33,40%20Installation%20Instructions.pdf top the pressure by the filling loop
Jan 23, 2011 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Heating pressure gauge goes up
yes tami
there should be a pressure rellief valve fitted.
it also sounds like the heat exchanger is blocked if the hot water is not as good as it used to be and the boiler reaches temperature too quickly then there is scale in the heat exchanger and needs to be cleaned or replaced
Mar 27, 2009 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
989 people viewed this question
Top ACCO Brands Water Heaters Experts
Paul Carew
Gil Shultz
Are you an ACCO Brands Water Heater Expert? Answer questions, earn points and help others
