Question about Sony KV-32FS13 TV
Sony Trinitron, no picture, sound works fine.
We have a Sony Television Model KV-32FS13. Without warning, the picture pulled away from the sides and slid down to the bottom of the screen as if it were a poster. Then the picture disappeared, replaced by some horizontal lines of color. Sound is unaffected. The pic sometimes comes back momentarily when the tv is moved. Any ideas? I'm afraid to open up the back without guidance - too ignorant of the mechanisms inside.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    If you are unfamiliar with TV circuits and electronics then should not open back cover and best thing is to call TV tech to fix it.
  • 4,234 Answers
There are potentially dangerous high voltages present inside the set even when unplugged, so caution is required. That being said, if you can solder, you may be able to resolve this. If the picture returns with movement, it is possible that the problem is poor solder connections. Try removing the back and sliding out the main board. Resolder any connections that appear grasiny or have rings. That may resolve the problem.
Keep us posted.
Dan
Posted on Feb 04, 2009
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS13:Pictured slightly bowed down at sides
Your symptoms sound like you have a problem in the pincushion circuit.
I would recommend you have a technician take a look at this, as this can be a tricky circuit to trouble shoot.
Aug 15, 2009 | Sony Televison & Video
Sony trinitron kv-32fs13 32''
when the lights flash those are codes that tv repair men have.youd be better off buuying a new tv,they are less than 500.00 nowadays
May 20, 2009 | Televison & Video
Need help adjusting the screen size on a Sony Trinitron KV-32FS13
try to adjust the yolk away from the picture tube
Jan 13, 2009 | Televison & Video
Sony 36" trinitron
check the horizontal output of your tv sets,if shorts need to replace it.
Jan 11, 2009 | Sony KV-32FS13 TV
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Sony KV-32FS13 TV Logo
140 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
