Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile - Revving sound intermitently
Always hums; but the rev- ving (increasing and lowering sound ) sound is new and am wondering if there is an issue.
    Problem Solver:
  • 13 Answers
The evaporator fan is supposed to speed up when the fridge needs to cool down quickly; then slow down. So if it's just a normal sort of loud/soft whirring, then that's normal.
But if you have ice buildup on the back wall and roof of freezer, then you have encountered the dreaded GE crappy defrost system flaw. That causes ice to build up everywhere you can see, and where you can't see, like on (and in!) the evaporator motor. When the motor kicks into high, it impacts the ice buildup, and buzzes like a chain saw.
Solution is to unplug the fridge and let all the internal ice melt. Or get a blow-dryer or heat gun and carefully heat the freezer back wall, etc. Don't get it too hot, or you can melt the plastic!!! Be patient.
See complete info here.
Posted on Aug 26, 2010
  • 367 Answers
Sometimes the evaporator fan makes this noise. This could be a sign of it going out but i wouldnt worry about it untill something actually goes wrong.
Posted on Feb 03, 2009
My car vibrates causing this loud hum while
Hi:
;You most likely have a wheel bearling or hub assembly that is bad. You should be able to narrow the hum down to one side or the other. Other possibilities are a noisy engine accessory, such as a bad bearing on a alternator, or power steering pump, but you should be able to make that noise show up, just by rev ving up the engine, so if it only shows up when the car is moving, check out your wheel bearings.
Dec 15, 2009 | 2004 Dodge Neon
Takes 2-3 hrs to dry a load. Put new dryer hose on. Vent not clogged. Lint filter cleaned each load.
Dryer turn on makes a humming noise intermitantly and won't dry at all have changed coils. It's not the fuse or vent. Help??
Nov 24, 2009 | GE Profile Harmony DPGT750EC Electric...
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
Car revving high
it is your idle sensor which needs to be replaced and this is right up on the firewall. it is right next to the manifold.
Jul 26, 2009 | 1996 Toyota Camry
Mitsubishi gallant 1992 V6
Check your MAS mas air sensor.
Jul 18, 2009 | 2000 Nissan Maxima
The engine revs increase when the engine gets warm.
Sounds like you are running lean. you may need to find an air leak in the intake tracked of the carb and motor. or the carb is dirty or miss adjusted pilot screw.
May 27, 2009 | 1997 Honda CB 500
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
429 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
