Question about HP Compaq Presario V2000 Notebook
System failure to boot
When I turn on the computer the display continuously cycles on and off through the following screen"
Intel UNDI, PXE-2.0 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 (020326)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM.
No amount of button pushing alters the problem.
  • thales Feb 07, 2009
    I have the same problem on Compaq v2615US. I've replaced with "known working" hard drive but it killed this on also. It now gives the same error and can no longer be recognized in external enclosure.
  • 916 Answers
Check you hard disk drive and make sure it is connected correctly. Is there a new hard drive in the device? If so you will need to install windows onto it. Otherwise as Ekse has said run the recovery console from your windows cd.
Posted on Feb 04, 2009
    President:
  • 2,559 Answers
This error can be caused by one or more of the below possibilities.
  1. Drive not bootable.
  2. Bios or Cmos improperly setup.
  3. Hard drive doesn't have a bootable file.
  4. hard disk is bad or connected wrong.
Solutions: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly
  1. Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
  2. Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
    - Floppy drive
    - CD drive
    - Hard drive
  3. Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
  1. Boot from a bootable floppy diskette.
  2. At the A:\> type fdisk <press enter>
  3. If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected properly.
  4. If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
  5. If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
  6. Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
  7. This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
  8. If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
  1. Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
  2. Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
The hard disk drive is bad or not connected properly If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Please rate this a fixya
Posted on Feb 03, 2009
  • HP Master
  • 13,433 Answers
Hi
The computer is unable to start from the hard drive and there is no cd in the drive to start from. so the last option it has is to try starting from network and it fails at that obviously, it requires a special server for that.
So try a windows installation cd or a recovery cd if you have one.
see if that boots.
Also when the laptop turns on you could enter the setup and check the boot order, it might be wrong and also check that the hard drive is detected in bios.
If you need more assistance let me know.
Thank you,
Ekse
    President:
  • 2,110 Answers
    - Floppy drive
    - CD drive
    - Hard drive
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
My intel desktop DG31pr suddently just restarted and now it won`t turn on again. This is what's on my screen at the moment: Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Jul 26, 2011 | Intel DG31PR Motherboard
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check...
You probably have the bios set to boot from a network, instead of the hard drive.
Find out how to get into your bios as the computer is booting (maybe F8, maybe ctrl-s?) then change the boot order to HD first, followed ny C D-ROM, followed by floppy, then network LAST.
FiOS-Dave
Aug 15, 2010 | Computers & Internet
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
PC will not boot.
Hi , without explaining all that is happening ,your pc harddrive has failed.The pc is looking for an operating system but cannot find it.
Dec 08, 2008 | Toshiba Satellite A135 Notebook
Acer Aspire 9410-4933 not booting up
YOU NEED TO REINSTALL OPERATING SYSTEM ... FORMAT THE ACTIVE PARTITION AND REINSTALL
Sep 15, 2008 | Computers & Internet
ACER Aspire 3050: Operating System not found
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Sep 11, 2008 | Acer Aspire 3000 Notebook
Hard drive clicks + error appears on screen when turned on
I would check to make sure the hard drive is in secure and if it is I hate to say it sounds like your hard drive needs replaced.
Aug 04, 2008 | Toshiba A75-S125 Satellite Notebook
HP Compaq Presario V2000 Notebook Logo
328 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
