Question about Compaq Presario Notebook
Local drives not opening
I HAD INSTALLED LOCATE PC.AFTER THAT I AM UNABLE TO OPEN LOCAL DRIVES NEITHER BY CLICKING THE ICONS NOR BY RIGHT CLICK.com
  • NOOR AHMAD
    NOOR AHMAD Feb 05, 2009
    THANXXXXX,BUT COMMAND PROMPT IS NOT RECOGNISING THE COMMANDS GIVEN BY YOU
    Problem Solver:
  • 7 Answers
Try the following...
From the start menu click "Run".
Type "cmd" and press Enter, this will launch the command line editor.
Type "x:" without quotes, where "x" is the drive you cannot open in explorer.
Type "attrib -r -s -h autorun.inf" and press Enter.
Type "del autorun.inf" and press Enter
Repeat this for each local drive that will not open.
Restart your PC.
Hope that helps!
Posted on Feb 03, 2009
How do you set up an external hard drive?
Turn your computer on and plug the external hard drive into the computer.
Open "Computer Management" by clicking "Start," "Control Panel," "System and Security," "Administrative Tools" and "Computer Management."
Click "Disk Management" in the left pane under "Storage."
Locate your external drive from the list of hard drives connected or installed on your computer.
Right-click the drive and select "Format."
Select a file format from the drop-down menu. Choose "NTFS" if you will be using the external hard drive with a computer that uses Windows 7, Windows Vista or Windows XP.
If you will be using the hard drive with an older version of Windows, select "FAT32."
This is a much less common format.
Click "OK" twice and your external drive is formatted. Once the drive is formatted, it is properly set up to be used with your computer.
hope this helps
Sep 10, 2012 | Computers & Internet
I have partitioned my LG 500G portable hdd into 2 drives(LG1 and LG2). But now my pc can only detect the LG2 and the LG1 has become "Local Disk". And when I select the Local Disk,the pc is keeps...
Open My Computer or Computer. Right click on the LG1 drive and select Properties. Under Tools, run the error checking disk utility. If it doesn't find and fix the problem, move on to...
Open Control Panel, then Administrative Tools. Open Computer Management. Open Disk Management. Right click on the LG1 partition and delete it. Right click on the empty space and create a new partition by following the prompts. Format, and you're done.
Good luck.
Jul 07, 2011 | LG XD2 500 GB USB 2.0 Portable External -...
I want to transver my photos and music to and from my mobile to my pc
Plug in your mobile to your pc. Once the computer recognizes the "new usb device" which is your mobile, right click on your Start button and choose Explore. It will open you the Windows Explorer window. On the left panel, under My Computer, look for the local drive letter associated with your mobile. click on it to show the contents on the right. Locate the folder containing those photos and select them and click and drag to your computer's local drive. That's it.
Sep 11, 2010 | Computers & Internet
How do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
By double clicking i cannot open my local drives
go to run
Type " regedit"
then find " ctrl+f"
in this box write "mountpoints2" and delete it ......
then again press "ctrl+f" again to find all mountpoints2 until ALL of these files are deleted
"there are a few of them!"
May 28, 2009 | Microsoft Windows XP Professional With...
Problem while opening hard disk drive.
unable to open my computer drives like C, D.whenever i double click the drive it show open with some programmes.I bought three month before.Begining it open when i double click but now it is not possible
Aug 14, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Hard drives not accessible
first go to run inthe start column type in msconfig when it comes up go to start up and stop most of the programs that are loaded at startup leave only antivirus. as all programs will work in normal way as you need them
go to windows explorer c:\ right click\properties\tools\check now tick the box Fix errors reboot. On rebooting windows will scan file system for errors and fix them
Jul 12, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Opening of drives
I have seen this several times and it is brought about due to a virus that creates an autorun file (autorun.ini).
In this file when you double click the drive, executes the file and in the autorun file exists any of the following: -
Microsoftpowerpoint.exe
smss.exe
.... or many others.
It is good thing that you have a strong antivirus which seems to have removed the viruses and therefore when the information file is opened, it does not find the executables it was supposed to run. That is why it asks for a program to open.
You can prove this by right clicking on the drive to see a shortcut menu and in this menu, the bolded menu will be the action taken when double clicked and the possibility is that you will find Autorun bolded.
To resolve the issue do the following:
1) Open My computer program or windows explorer.
2) Right click on the drive and open or explore it.
3) Locate the file Autorun and delete it. If the file is not shown, from the folder options choose show all files. This is because sometimes this file may be hidden.
Try double clicking the drives again to see if you get he same error.
NOTE: Many virus developers have made possible for people to install/run viruses in there own computers by simply double clicking the drives like flash disk.
May 31, 2008 | Microsoft Windows XP Professional With...
Duuble clicking problem
If this issue is only relevant in the My Computer folder I would ensure you do not have any viruses or other malicious software installed.
Also, check your mouse setting for the double-click function
START>CTRL PANEL>PRINTERS & OTHER HARDWARE>MOUSE (XP View)
START>CTRL PANEL>MOUSE (Classic View)
Then on the BUTTONS tab there is a section for Double Click speed with a folder icon for testing it out. Make sure it is set as required for your use.
Nov 19, 2007 | Microsoft Windows XP Professional With...
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
