Question about Hotpoint Dryers
Hotpoint aquarius condenser dryer TDC30
Have washed the condenser unit through with a hose to get the fluff out. Was this the correct way to clean it? Also, can i put it back in and use it when its still wet? manual doesnt say. I have a TDC 30p Tumble dryer. I need to change the thermostats. I've found the two at the rear od the machine. Can you tell me where the font thermostat is located.
  • 979 Answers
I would dry it just to be on the safe side, even though it doesn't say so. It can't hurt. The front t'stat should be under the top at or near the drum.
Posted on Feb 03, 2009
Where can I locate the tumble dryer condenser and fluff filter for my hotpoint Aquarius extra WD64
from hotpoint web page spares
from you local hotpoint service agent spares section
Jan 28, 2017 | Hotpoint Washing Machines
My hotpoint condensed dryer is steaming up my windows and I don't know why as I thought that was the point of the condenser. It's model number is Tcm 850, anyone got any suggestions or can help, thanx
Hello Scot, just make sure the fluff filter is clean and the exit tube for the air is clean they should just slide out fluff filter and pull off the fluff and the air exit tube normally get quite dirty with fluff and debris. So take that out and take it outside and wash it through with a hose from both ends. The water tray should also be emptied regularly but the panel will tell you when that is full.
Hope that helps
Steve
Oct 12, 2013 | Hotpoint Dryers
Hotpoint Aquarius WD440 1400spin. How long can the vent pipe From the Dryer be ???
If it is washer dryer, then it does not need ventimg, as it is a condenser type dryer, which condenses the steam back to wate therefore no hose neededr
Nov 01, 2010 | Hotpoint Washing Machines
How do i clean the condenser on my hotpoint tdc32?
Remove condenser, and flush it out under a running tap, or hose pipe with cold water, this will flush all the fluff out of the condenser
Please rate my solution.
Thanks.
Aug 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpont aquarius condenser dryer wont heat
There are a number of reasons for dryer not to heat, first and foremost is failure of the stats and or element. You will find these located behind a removable cover at rear of dryer.
If you know how to use a meter, then test these for continuity.
If o/k then it gets more involved as there are several other possibilities and you need to know what you are doing.
The only other thing to check is that all the filters and air inlet and outlet vents are clean, particularly the one at the front left. pull out and wash under running water to flush all fluff out.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpoint Aquarius dryer TDC30. The 'Empty Water' light stays on even though the reservoir has been emptied. The machine runs but does not warm up. Is this a common problem? has the element...
Float chamber is bunged up ,at the rear of the dryer at the bottom is a black plug / cap pull it off and stick a pipe cleaner
or long cable tie metal coat hanger in it to clear the old wet fluff (have some kitchen roll handy as some water comes out with the wet fluff),
other wise its a total strip down to clear the chamber out.
Oct 29, 2008 | Dryers
Well i put it back and used it when it was still a little wet and all seemed ok! Still working fine and nothing went bang!
Apr 27, 2008 | Washing Machines
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Dryers Logo
517 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
