Question about Compaq Presario Notebook
Compaq Presario Vista Line In Recording Distortion
I have adjusted the (Line in/ Microphone in) volume levels as well as my Roland MC-909 output levels. I use Goldwave recording software(v5.25) have been using Goldwave on a Dell XP for 4 years. I had this laptop about 30 days.
  • 3,940 Answers
I was having similiar issues with my Vista system, upgrading the audio driver resolved the issue for me.
Posted on Feb 09, 2009
In my gr 33 the volume is very low. mistakenly i did a factory reset after that the volume is becomes very very low. Any solution for this problem?
There is probably both a global volume and individual program violume as well. One or both may have reset to a lower level and need to be turned up. It's also possible that the general output has a setting for line level or instrument level, which may be software controlled. Take a look through your manual to find these settings and adjust to suit.If all else fails, contact Roland Customer Service at this link for help.
Roland Company Contact Us Contact Us
Sep 15, 2016 | Roland Gr33 Guitar Synthesizer
I receieved a pair of Koss SB145 headphones without the instruction manual. It has two connectors and I am clueless how to record things etc..
I suspect that you actually have the Koss multimedia headphone/microphone model SB/45 as shown on the right earcup, not SB145.
If this is the case, the 3.5mm connector with the black plastic (contains a headphone symbol molded into the plastic) and red insulation bands separating the conductors is for the stereo headphones. The other 3.5mm connector with the tan plastic (contains a microphone symbol molded into the plastic) and black insulation bands is for the microphone.
You need to plug these into the microphone input and headphone output connectors on your computer or whatever device you are recording with. Then adjust the microphone input audio level and headphone output audio level on your recording device. Consult your manual for your recording device to locate the correct connectors and for instructions to adjust the audio levels.
Also, be sure to check and adjust the volume level control on the headphone cord if you don't hear anything after correctly connecting them to your recording device and adjusting the levels.
Aug 14, 2011 | Audio Players & Recorders
Sound&microphone
How to adjust microphone volumeTo adjust the volume for your microphone in Windows 7 or Windows Vista, follow these steps:
  1. Click Start, type mmsys.cpl in the Start Search box, and then press ENTER.
  2. In the Sound dialog box, click the Recording tab.
  3. Click Microphone, and then click Properties. Note Make sure that Working appears under Microphone. If Working does not appear, click Microphone, and then click Set Default.
  4. In the Microphone Properties dialog box, click the Custom tab.
  5. Select or clear the Microphone Boost check box.
  6. Click the Levels tab.
  7. Adjust the volume slider to the level that you want, and then click OK.
  8. Click OK to close the Sound dialog box.
How to adjust the voice setting
  1. Start the game.
  2. Sign in to LIVE (use the Guide).
  3. Click Personal Settings.
  4. Click Voice.
  5. Make sure that the Recording volume level meter registers at least one bar when you speak.
  6. Click Done.
How to adjust Windows volume settings
  1. Double-click the volume icon in the task bar.
  2. Click Mixer.
  3. Move the sliders up or down as appropriate.
    Note You can also click the speaker icon at the base of each slider to toggle "mute" on or off.
Jul 01, 2011 | Computers & Internet
Microphon driver
All drivers for this PC can me found at http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3650962#N142
Generally speaking, however, microphones do not have drivers. You should make sure that the recording volume for your microphone is turned up.
  1. Click Start vistastartbutton.jpg, type mmsys.cpl in the Start Search box, and then press ENTER.
Mar 07, 2011 | HP Pavilion DV6700T Notebook PC
My microphone on Presario F762NR stopped working i did troubleshooting and it did not find any problem! maybe it is turned off somewhere and i don't know where!
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 18, 2011 | Compaq PC Microphone (Black or Beige)...
Where is the line in jack for my Gateway MC7321u Notebook? Is it one of the headphone jacks?
Some computers have a special jack labeled line in. If your computer does not have a line in jack, you can use the microphone jack. You can then adjust the volume of the device in control panel under sound options. The headphone jack is only for output. I have seen some computers where you plug in a cable to the microphone jack and you will be asked what kind of device it is.
Jan 17, 2011 | Gateway MC7321u Notebook
Downloaded skype. I can receive and hear the calling party, but they are unable to hear me.
This is the issue regarding the Internal Microphone in the Computer.
Your contacts cannot hear you, until you have enabled the Microphone in the Computer.
You will find the information to enable the Microphone below:
Windows XP:
1) Double-click on the Volume Control. 2) Select the "Properties" option from the "Options" menu. 3) Select the "Recording" option in the "Adjust volume for" section. Click the OK button. Check the box labeled "Select" under the microphone volume and you should now be able to adjust the volume for the microphone.
Windows Vista:
1) Right Click the Volume Icon at the bottom right corner of your screen [The Task bar]. 2) Click [Playback Devices]. 3) Right Click the [Speakers] Icon and click Properties. 4) Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback.
Windows 7:
1) Click on Start (the Windows icon) and type sound. 2) Click on Sound under Control Panel. 3) Click on Recording tab. Select Microphone and click on Properties. 4) Click on Levels tab. The default Microphone Boost is set to 0. Increase it. 5) Close all the dialog boxes, and the microphone will be ready for use.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite P105-S9337 Notebook
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Microphone is not working
1-adjust the overall volume by pressing fn+f 5 hotkeys
2-adjust sliding mixer controls by doubleclicking the speaker icon
3-disconnect the headphone jack to enable check of internel speaker.4-confirm that microphone plug is proper connected to mono mic jack.5-confirm that microphone is selected as recording source in control panel----multimedia and recording level is adjusted.
confirm that sound source is selected in control panel----multimedia
confirm that headphone connector connected in right postion
Jan 24, 2008 | Compaq PC Microphone (Black or Beige)...
Compaq Presario Notebook Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
