Question about RIM BlackBerry 7290
Rim Blackberry 7290 will not charge battery, does not exhibit the "charging icon" when it is plugged into anything. Where can I get it repaired ?
  • George McBride Feb 03, 2009
    Hi, I'm not sure if you received my reply. I wrote it here in the box and clicked on the "Helpful" icon.
    Thanks again,
    George
    Thank you very much for your reply !!
    Unfortunately, I took a very close look at the connector with an eye loupe and found that the pin on the edge of the data/power connector (right most pin with the display pointed at the ceiling) has been bent down and pushed to back of the connector. That is probably the connection for the charging voltage. Where can I get the connector replaced or purchase it so I can replace it myself ?
    Thanks again,
    George
    Scholar:
  • 61 Answers
I do apologize you're having this issue with the Blackberry. I assumed have you have tried different outlets. Try to remove the battery completely for 20-40 seconds, and let it re-boot and try again with putting the charger in. Is it loose? Do you have another charger?
If the icon is not coming up, it's something with the OS we have to update.
You can check out www.blackberry.com/btsc for the desktop manager, and the latest and great software for you style of blackberry. They have number on their for return and repair as well.
Running the application loader is like giving the phone an oil change. You wanna do it 1-2 times a month to keep it moving smoothly. RIM updates their softwares every 2-4 months.
If this is a T-Mobile blackberry check out www.t-mobile.com/bbupgrade
You can desk the battery, but as I said if the icon is not coming up, it's a software problem.
Cheers!
Posted on Feb 03, 2009
Hi mate i have blackberry 7290 its problem is whe i power onthe phone its giving following error "DEVICE ERROR:365 RESET" then i try to flash the phone but soft ware giving this message UNABLE TO...
Try uninstalling the Blackberry Software Suite and the Blackberry drivers from your computer from the device manager. Power off the Blackberry, then connect it to the USB cable to see if it begins to charge. Look for the device to show up on Windows. If it does not show up, try booting the Blackberry device back up. If you're still not seeing anything (and especially if the phone isn't even charging), it could possibly be a hardware issue.
Mar 18, 2011 | RIM BlackBerry 7290
How to turn on the blackberry?
The blackberry 7290 turns on by itself once its charged enough. Here is the link for a manual download, once you go to the link just click below the picture of the phone where it says "download manual"
http://www.cellphones.ca/cell-phones/blackberry-7290/
www.usedcellphoneshop.com
May 17, 2010 | RIM BlackBerry 7290
Blackberry 7290 battery icon with line hrough battery
This can indicate that the battery can no longer hold a sufficient charge for the device and may need to be replaced. To be sure, you can download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Jan 11, 2010 | RIM BlackBerry 7290
My blackberry isn`t charging, i`ve plugged it in and nothings happening, when i plug it into my computer it has a lightning symbol by it but im not sure what it means?
does the phone charge when connected to the computer? The lightning icon means it is connected to power and is charging. Try another charger, it seems like your charger is the problem, not the phone.
Dec 15, 2009 | RIM BlackBerry 7290
I need the drivers for rim blackberry 7290 for connecting with my laptop . how i can do that ?
if you have a computer charger for your blackberry just use the charging cables.
Oct 22, 2009 | RIM BlackBerry 7290
I have a blackberry that will not turn on and everytime i try to charge it there is a red light for about three seconds and then there is no light.
first things first, buy a new battery charge it completely +16 hours and then turn it on , thats when you will see if you have a technical problem
Aug 31, 2009 | RIM BlackBerry 7290
Just stopped working, cannot charge, red light only
It could need a new battery. It doesn't sound like it's holding a charge anymore.
Apr 14, 2009 | RIM BlackBerry 7290
Battery escape in a Blackberry 7290
It means that your battery is not seated properly, I just searched the blackberry forums, and it seems to be common when removing the battery, unless seated properly it will deplete the charge faster than normal, I hope this helps you, thanks for using FixYa, peace Gym
Dec 18, 2008 | RIM BlackBerry 7290
Blackberry 7290 mobile
The manual for this phone is available here.
Download the PDF and open the file with Foxit or Adobe Acrobat.
Nov 18, 2008 | RIM BlackBerry 7290
Blackberry 7290 - Will not trun on
Unit is defective or the software needs to be reset/reflashed.
- J.
Mar 12, 2008 | RIM BlackBerry 7290
RIM BlackBerry  7290 Logo
747 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
