Question about Kenmore 53082 / 53084 Side by Side Refrigerator
Kenmore Refrigerator 106.53502300
Two nights ago my wife and I came in the house to a very slight electrical burning smell. We pinpointed it to our Kenmore 2-door and quickly realized that it was also making a clicking sound sporadically. The clicks were coming every 30 seconds to 5 minutes. The unit seems to be cooling both sides and the ice and water are still working as they should. I unplugged the unit fearing that it might cause a fire.
Last night after learning that the clicking is the overload, I plugged it back in to see if it might be overheating. Almost immediately it began clicking again so I don't think that it is a matter of dust or grime overheating it. Also, it again seemed to be blowing cool air, though I didn't let it run long enough to see if was getting down to temp.
Is there a way to determine if it is simply the overload that has gone faulty or if in fact I need a new compressor / unit? Can I allow it to run long enough to see if it is properly cooling without damaging the compressor?
  • hvac chic Apr 11, 2009
    I have the same model and the relay that plugs on the compressor was bad, completely charred. I wound up purchasing an after market start capacitor type for about $12 from our local refridgeration supply house it has been fine for about a year now.
  • brenmbly
    brenmbly Aug 04, 2013
    We had the same problem. Called sears and repairman did the same.He said all the new models are having this problem and you just replace it and your good to go. it just cost more with the repair man comeing to the house. I renewed the warranty and it saved me the $150 service call and parts. His total was about $230 and the warranty was about $120 and change. Might help
    Sergeant:
  • 311 Answers
Sethjames,the relay can fail and the compressor could still be fine.as a serviceman in your home i would pull off the relay and ohm out the compressor.their are three pins.i would put a meter probe to ground[scrape the probe into the metal of the compressor]and then touch each pin with the probe one at a time.you should get no reaction on you meter,if yes, then the internal motor windings are shorted to ground.now if that test's ok,next you put one probe on the common pin[most brands its the top of a triangle formed by the three pins]and the other would go on the start or run pin.the measurements/or readings would be like this if normal.common to start winding from about 1.0 ohms+- maybe .3 ohms,common to run wining about 1.5 ohms+- .3 ohms .the newer more efficient your compressor the lower the numbers the older the unit the higher the numbers,because the energy standards were less .if readings in the 3.0's that's not good [although ive seen boxes that were 15 to 20 years old working fine and were drawing about 4 amps],so resistance,ohms would be higher [dont mean to confuse you there mixing ohms and amps].also if you had an amp probe you could clamp it over one wire and that would tell you how hard the compressor is working.should be about one amp in the run winding[in a newer box]on my truck i carried a universal relay that was rated for certain horse power.it was best for me ,then only needed one part for all makes.wholesale in 2007 it was less than 10$.with on line access it may be just as easy for you to get the original.but i would think twice if cost was quite abit higher.i hope that helps abit ill be there if you need more advise God bless ,tom
Posted on Feb 03, 2009
Slight smoky smell and freezer food/ice taste smoky
sounds like your motor is is burning out or someing inside the fridge is burn
Nov 19, 2013 | Kenmore Refrigerators
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
I have a Sears Kenmore washer (Model # 11092281100). I replaced the motor coupler, and I checked the alignment of everything before reconnecting the motor clamps/clips. It seemed like the motor shaft was...
It could be the grease. It could run without noise if it was not installed all the way. Here is a link for properly installing Motor coupler video Now if everything looks right it is probally just the grease.
Nov 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Freezer is all deforsted. Fridge is 5 years old. We smelled a burning smell 2 nights ago and now everything is defrosted. We couldnt tell where the smell was coming from in our house. Motor is running....
If the evaporator (freezer) fan and the condensor (bottom rear) fan are both running but you have no cooling at all, the odor you smelled was probably the compressor start relay/overload device. It would be in your best interest to have a professional service technician look at it. Proper repair could mean the difference between a $60 part, or a $300 compressor. Prices are for the part only.
Dec 23, 2009 | Refrigerators
Model 106.53632300 couple of days ago smelled something (burned electrical type smell). Now both fridge and freezer not cooling. Cooling fan in back on bottom is running.
you may have a fried start or run cap and hopefully not a spendy board like everything runs on these days....bad caps(capacitors) will cause compressor not to start and run but arent needed for fans to kick on ....
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
A rubber burning smell from my refrigerator
It could be overheating of the compressor and its surrowndings but could also be from the new type of insulation that are being used nowadays.........sodeep
Jun 19, 2009 | Kenmore 57029 Side by Side Refrigerator
Bosch Model SHU4006C Dishwasher
I just bought a Bosch made for Sears and I'm trying to return it. I'm going to get a Kitchaid instead. We got ours two months ago and Sears is being difficult in letting us return it. I had a technician come to the house and he said it smells--slightly oily or rubbery. I went to a store and all of the Bosch dishwashers smell. Anyone reading this, don't get the Bosch.
Jan 03, 2008 | Dishwashers
Whirlpool GC5SHEXN Side by Side Refrigerator burning smell
How long had it been plugged in when you started to smell the burn. What kind of burn do you smell, is it an electrical burning smell or a smoldering dust burning smell.
supertechks
Nov 21, 2007 | Whirlpool GC5SHEXN Side by Side...
Kenmore 53082 / 53084 Side by Side Refrigerator Logo
409 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
