Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire PLD4460REC Dishwasher will not start
Pressing the Start/Cancel button does not start the dishwasher.
Normal Wash cycle is selected and Delay Start is not selected.
I tried shutting off the circuit breaker and turning it back on, but this did not help. I have a flashing segment on the panel with the Start Cancel button with the door open, and it stops flashing with the door closed.
  • 32 Answers
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Frigidaire FFBD2406NW0A then clean wash drying and 4 hour led lights are blinking
I appreciate your post, friend!
I understand that the clean, wash, and dry buttons on your Frigidaire dishwasher are blinking along with the four LED light. This appears to be a delay start cycle. I would recommend pressing the cancel button. If that does not clear the lights you can perform a reset and to do that you would need to disconnect power from the dishwasher for roughly ten minutes. I hope this is helpful. -Matt
Feb 20, 2015 | Frigidaire Dishwashers
What does a 5h code indicate
The GE dishwasher error codes I have seen start with a letter (usually "C") not a number. I suspect that this isn't an error, but an indication that you have activated the system to delay starting the dishwasher. I believe 5h represents a 5 hour delay. Pressing the "Delay" button should cycle through the different selections and eventually bring it back to Zero.
Feb 07, 2015 | GE Dishwashers
Power failure
  • Find the "Start/Cancel" button on the dishwasher's control pad. This button is located on the far-right side of the pad on most Frigidaire Gallery dishwasher models.
  • 3 Press the "Start/Cancel" button to clear the "PF" error code. Resume using the dishwasher as normal. You may have to reselect and start your cycle from the beginning.
Dec 02, 2013 | Frigidaire FDB520RH Builtin Dishwasher
Purple light is on and cycle won't start
It's possible that you have put the dishwasher into delay mode. Try powering off at the powerpoint as this will force a reset of all programming.
The pause/start button also sets the Delay Start feature which can delay the start of a wash program
from 1 to 12 hours.
To cancel Delay Start
Press the I button.
Dec 30, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
Wash cycle does not start. I push the normal wash (or any other cycle) button and a tiny amount of water flows. If I leave it alone, eventually, several lights start flashing. I have tried pressing the...
Either the hose is clogged at the entry point to the dishwasher or the solenoid vlave is bad...
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 21, 2010 | Dishwashers
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
811 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
