If it doesn't come back to life when you disconnect from power, then reconnect, it's probably an internal fault and you need to consult an HP service outlet or competent technician
If the touch screen on your 2005 Jaguar X-Type is blank and you are receiving codes 50 and 51, it indicates that there is a communication error between the audio control module and the touch screen display.
Here are a few things you can check:
Wiring and connections: Check the wiring and connections leading to the touch screen display and the audio control module to make sure they are in good condition and properly connected. A loose or damaged wire can prevent the display from working correctly.
Audio control module: The audio control module is responsible for sending information to the touch screen display. If the module is malfunctioning or damaged, it can prevent the display from working properly. Check the module for any signs of damage or wear, and replace it if necessary.
Touch screen display: If the display itself is malfunctioning, it may need to be replaced. Check the display for any signs of damage or wear, and replace it if necessary.
Software update: There may be a software update available for the audio control module that can fix the communication issue. Check with a Jaguar dealership to see if there are any updates available for your vehicle.
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Touch pad is a thin glass layer that is available below the
display screen which interacts with the mobile when we touch. Since you have
not specified your mobile functionality; I think your mobile is working
properly when you use the Keypad. If your mobile is not working properly using
the touch alone then the touch pad in the mobile got affected. Touch pad in the
mobile can be replaced easily. Please visit the nearest mobile service center
and ask them to replace the touch with a new one. Nowadays touch screen are
available at very low cost.
probably your flex cable is already damaged. I already changed mine (once) - it fixed display and sound problem. check this assy/disassy guide: http://www.formymobile.co.uk/u900disassembly.php.
for the flex cable just search in ebay sellers. goodluck!
my lg's camera started to turn my phone off, i do tech work for a wireless company and when i was trouble shooting my own phone as a test i went to my camera and my screen went blank! i tryed every thing, but the master reset. because my screen is blank i need to know the number i will have to enter to get it reset from the key pad.
Check the power adapter, sometimes they get hot and they don't supply enough power to the pin pad. Also make sure that the power cable is not loose, twisted or broken, this can also contribute to the problem.
