Question about Pentax Optio S40 Digital Camera
Striped horizontal lines on picture
Any picture is very brightly lit
  • 244 Answers
Depending on whats inside your lens it is likely to be either:
1) The light filter has jammed or the ribbon connecting it has broken.
2) solenoid for the apperture shutters has jammed or lost power.
I fix Fuji's and Samsung's mainly so couldn't say for certain exactly.
Posted on Feb 03, 2009
Hi, my Panasonic Lumix DMS-TZ2 is making horizontal lines over the pictures that I take. What is the cause of that?
Not sure it is on every picture you take, but digital cameras doe have problems with bright lights in a dark environment. From such a light bright lines can go horizontal. If in normal light, your camera does not have the problem, I guess you now have an explanation.
May 27, 2014 | Panasonic Lumix DMC-TZ2 Digital Camera
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Dropped my casio exilim ex-z85a camera and now when I take pictures, there are light horizontal striped lines running through the entire image
By dropping the camera you have caused some shock damage to the LED display so you will no doubt have get it repaired.
Saying that, if you copy the pictures to a computer you may find that the pictures are fine.
Regards.
Aug 11, 2009 | Casio Cameras
Overexposure and horizontal-striped image
Hi!
No, it's not a software problem. The problem is that the shutter doesn't work so it can't control the amount of light taken so the pictures are very bright with horizontal lines. There are usualy two causes - a broken shutter cable inside the lens or the shuuter blades are stuck - may happen if the lens get wet or something adhesive gets in it. It's a hardware problem so I suggest you contact local Canon or other camera service center. It is considered a hard repair so it could get expensive. I don't think it's worth it, so I would suggest you get another camera.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot A420 Digital Camera
Picture taken is so bright and with trasparent horizontal line
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-s600 overexpourse
Feb 24, 2008 | Casio Exilim EX-S600 Digital Camera
Bright white horizontal stripes - Symphonic 27
YOUR brightness on the high voltage block is too high...turn it down
Dec 02, 2007 | Televison & Video
Image looks with white verital striped lines in playback mode
Mine had the same problem (except the stripes are horizontal).  I sent it to Canon and sure enough it is the CCD problem that many of these have.  The good news is that it is covered under a recall and Canon will fix it free, including the shipping.
Oct 18, 2007 | Canon PowerShot S1 IS Digital Camera
Very Bright Outdoor Photos with lines
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open. You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
Mar 30, 2007 | Casio Exilim EX-S600 Digital Camera
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Pentax Optio S40 Digital Camera Logo
85 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
