I Have was given an Infocus SP4800, It just stop working is what i was told, I was guessing it was the lamp, got a new one installed it now it will turn on, but no picture, I get a blinking red light. I have tried to reset the lamp timer, but it doesn't seem to be that, any thing else to try ?
check the lamp hours in the menu. if it's close to the end of the lamp's life, it'll need replacing and the timer reset. if the lamp is ok, i'm going to guess it's overheating. blow the dust out of it with canned air and try again. if it still shuts down, you have a power supply problem.
make sure the colorwheel is spinning. if it is not, replace it. also, blow the dust out of it with canned air. excessive dust kills lamps quickly. you'll also need to reset the lamp timer. are you using an sp-lamp-009? the sp-lamp-018 looks exactly like it, but is used in th x1a and x2. the x1 only uses the sp-lamp-009. if all else fails, replace the power supply.
there isn't one. you need to see the menu. but what color is the led and is it blinking?
green- all is well
red blinking:
1 time- lamp not striking after 5x.
2 times- lamp has more than 3000 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fan failure. shuts down.
5 times- undiagnosed error. possibly ballast or colorwheel.
if the colorwheel won't spin, the lamp won't light. when you turn on the projector, do you hear a high-pitched whir? if not, the colorwheel needs replacing.
it there is no high-pitched squeal when it starts up, the colorwheel needs replacing. the lamp won't light without it. the part is under $50, but installation is quite involved.
do you have the correct lamp? the x1a takes an sp-lamp-009, that has 2 white wires, and not the more common sp-lamp-018 which looks exactly the same except has one white and one red wire (and are in different plug positions). if it still doesn't light, there is another issue (possibly the colorwheel) along with the lamp timer reset.
The owner's manual should have a troubleshooting chart that will indicate what the blinking lights mean. If the new bulb did not clear it, the problem may be the ballast (part that starts the bulb). Also, when you replaced the lamp, you should also reset the lamp timer. Some units will continue to indicate a lamp needing replacement until the counter is reset. The procedure for that should also be in the manual.
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
