Question about GE Microwave Ovens
Grid in door is discolored,rusty looking,moisture build up on gla
Took door off but not sure how to remove inside panel to clean it up.
this microwave is a G E jvm1533bd 002 dom is 2002
can this be done? how can you stop moisture from showing up on inside of door glass. any help would be greatly appreciated thanx
  • GE Master
  • 9,098 Answers
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Moisture can show up if a filter is clogged or air flow is otherwise limited or blocked.
You can download GE owner's manuals and installation instructions here.
Posted on Feb 08, 2009
HOw do I get moisture that is trapped between the glass in the door out?
Open the door cover and clean it thnk there is screws there or clips
Sep 16, 2014 | Microwave Ovens
Door glass is lose and seal is leaking..moisture is forming on inside of glass
That is normally caused by the clear plastic adhesive cover either having been removed or missing. It covers the perforated door inner and stops condensation and food particles from getting inside the door cavity where is cannot be cleaned.
Feb 14, 2011 | Goldstar MV-1526 Microwave Oven
Cleaning the inside of the door glass, how do I remove the metal grid on the inside of the door?
You must not remove the grill as that is part of the door assembly and reflects the microwaves back into the cavity.
So no, you cannot.
Nov 26, 2010 | Kenmore Microwave Ovens
Ge jvm1542bf001 has rust discoloration on glass part of door. Took door off, removed handle. Is there a way to access the inner surface to rid grid of rust?
It would appear that no one knows how tofix this problem. I have the same problem and the only sugestions I get is to replace the door.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung SMH7177STE/BE
Is the hood vent exhaust fan running, and do you feel good air flow?
If not, please reply back.
If the oven is not venting properly, moisture can build up inside the cavity and door panels. This will cause a condensation or steam buildup that looks like smoke.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
As you're disassembling, be on the lookout for cracks. Once you clean it, if you've found any cracks, you can order Samsung parts here.
Oct 19, 2008 | Samsung SMH7178STD Microwave Oven
Inside front of oven door is a water build-up
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 09, 2008 | Thermador MBBS Microwave Oven
Kenmore Over the Range Microwave
If you think the window is stained, you ought to see the rest of the inside! Wife is probably right. (wink, wink, nod, nod)
Actually, you can take the cover off, remove the front panel without much effort and clean everything and get a lot more life out of it. Microwaves usually die because of heat related problems caused by buildup of yuck on the guts.
Hope Ya Make your Wife Happy!
Jan 24, 2008 | Microwave Ovens
Modelnn-h264/s254 1100 watts
This door screen as it's called protects the metal mesh screen from moisture and food debris. The door screen must be replaced or the mesh screen can arc and be damaged, which can lead to microwave leakage. You can order a new screen from Panasonic at: http://www.pasc.panasonic.com/Epartr/PartsListChoice.asp It may be this part: F31455H00AP DOOR SCREEN A 5.75 But it might be better to call Panasonic at 800-833-9626 and be sure this is the right part. Be sure to have your FULL model nuber (with suffix) when you call. Be sure to use a cleaner like acetone, etc. to remove all the old adhesive before applying the ne wone, or it will not stick. The door must be squeaky clean and dry.
Sep 21, 2007 | Panasonic NN-H264 Microwave Oven
Microwave Ovens Logo
391 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
