Question about ASUS Eee PC 900 Notebook
Keyboard wen i typing a s cam was o
  • Amardeep46
    Amardeep46 May 11, 2010
    Can you elaborate on the problem you are facing
N40bers 36c2 2ey w533 n6t f5x *r6b3e0
Easy go to bios sytem push del keyb or F2 wen prompt are begin and then inside the bios system diseable the keyboard on wen windows begin in advanced options or wen the windows are begin touch the caps look keyb in yor keyboard that's all enjoid it please coment !
Mar 05, 2014 | ASUS Eee PC 900 Notebook
Backspace button not working
you have to change the keyboard
Aug 02, 2013 | HP Computers & Internet
One board key is looked wat is solution
Suggest replace keyboard
Regards,
joecoolvette
Apr 16, 2013 | IBM Lenovo ThinkPad T60
Key board not work cortley
GO TO CONTROL PANEL AND LOCATE THE KEYBOARD CONFIGURATION,DEPENDS ON YOUR OS,THEN CHOOSE THE LANGUAGE FOR YOUR K-BOARD
Apr 21, 2012 | Computers & Internet
How do i turn off the keypad beeping sound, but leave the ringer on?
hi.
you should turn off "keyboard tones".
so first go to settings and go to sounds settings.
then go to tones. then go to keyboard tones.
turn it off
Jan 30, 2011 | Microsoft KIN Two Cell Phone
When i try to type on my computer the keys arnt working and they are all messed up wen i try to tyre on it how do i fix that?
The options you have to fix your keyboard problems are:
  • try to re install the drivers for the keyboard
  • if that doest work try using a different keyboard
Cheers!!!
Aug 10, 2010 | Microsoft Windows XP Media Center Edition...
Switched keys
Hello there:
you have got dirt or dust under the key. get some canned air and turn off the laptop and blow out the keys really good. than restart the laptop and you should be fine
Jul 22, 2009 | HP 386209-001 Keyboard
I WANT TO INSTALL A WEB CAM BUT IT IS COMMING ERROR AND ONE MESSAGE IS COMMING THAT THERE SHOULD BECD DRIVE
Wen you go the web cam, it should have come with a CD. If you have this CD you must insert it and download this programs in to your computer, then your computer will recognize the WEB cam.
Artgirl
Jul 14, 2008 | Cameras
@ key
This is a problem I had at onre time and it turned out that I had selected the USA Keyboard in stead of tthe UK Keyboard, you could have the same error or vice versa (ie Uk instaed of USA) so go to START then select CONTROL PANEL then select KEYBOARD and check which is selected and correct if necessary.
All The Best
Jan 02, 2008 | Acer NSK8458AN Keyboard
ASUS Eee PC 900 Notebook Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Tony
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
