Question about Casio Exilim EX-Z750 Digital Camera
Casio Elixim Camera will not pop out the Battery to charge.
This is the third Casio Camera I have had and I am not happy with the pop out battery that I have to charge in a separate battery charger. I prefer to place the entire camera in a self charging unit. Does anyone know of a camera repair that won't charge what the camera cost to repair?
    Problem Solver:
  • 14 Answers
I think the problem is either the charging pins are damaged or the IC itself. Either ways this is not a very expensive repair and Casio guys should do it for you for a reasonable price.
Posted on Feb 03, 2009
Casio NP20 battery does not charge,charger keeps flashing, does this mean I need new battery? also,it has 700MAH will 800 do when I replace it? was does this mean
If you have had the battery a long time or have charged it often it will need replacing if it does not charge.
800MAH is the capacity of the battery, how much power it can store.
800 is better than 700 and if it is a NP20 it will be OK in your camera.
Hope this helps.
Feb 21, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
How do you charge the battery? i don't have a lead with a plug on?
The camera uses a NP-40DBA battery, which fits into a BC-30L charger. The battery does NOT charge in the camera.
If you've lost the charger, you'll have to buy a Casio or a third-party replacement from your favorite local or online store.
Feb 04, 2010 | Casio Exilim EX-Z30 Digital Camera
I have the ex-s600 camera and am very happy with the camera but I just tried to recharge it and it never charges. The red light blinks continuously and never turns green.
Remove the battery and make sure the contacts are clean. It might even be sufficient (for a while) to just remove the battery and put it back in. If that works, you should clean the contacts.
The next step is to try another battery. If you can borrow one from a friend with the same model, do so. If that charges, your battery is bad. If it doesn't charge, ask your friend to try charging your battery in the other camera. If it charges, then try borrowing the AC adapter. That will help isolate the problem without spending money. If it goes this far, post a response on your results.
Dec 09, 2009 | Casio Exilim Card EX-S600 Digital Camera
I charged my battery and my camera won't turn on. It is a casio elixim. What is wrong?? It is only 2 years old.
Your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 26, 2009 | Casio Cameras
Won't turn on
If I put mine in backwards it won't turn on. the battery fits both ways so the only way to know is turn it around the other side.
Apr 11, 2009 | Cameras
Power button will not work - it did not pop up when depressed. I removed battery and card and re-inserted but button is still stuck. Any suggestions?
Found out that if battery needs charging, camera will not turn on at all. I guess I had a senior moment. Button was not stuck just no power to turn on camera. After charging battery everything is fine.
Feb 28, 2009 | Casio Exilim EX-Z750 Digital Camera
Battery Problems
ok my friends is very easy and let me tell you something wokrs.just take the battery of the camera and any transformer with output 9v put one wire on the (+)and another on the(-) after take you battery and put (+)--(+) and (-) for just 3 o 4 seconds that will reactivate the battery and put it back to the charger ,,,i tried my self and works good luck
Jul 04, 2008 | Casio Exilim EX-Z77 Digital Camera
CASIO EXILIM EX-Z70 BATTERY CHARGER IS FLASHING RED AND NOT CHARGING THE BATTERY
it wud flash red until it gets fully loaded..its normal...try charging for 90 mintutes..as that is when it is completely charged
Happy to help
HAve a nice day!
tc
May 11, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
