Question about Kuppersbusch Kitchen Ranges
K?ppersbusch KD9400.0GE Kitchen Hood SPARES
I NEED TO GET THE LIGHT/LAMP FITTINGS FOR THE HOOD. Please point me in the right direction to get the spares and instrcution book for the Kuppersbusch hob. Thanks.
  • admin894 Feb 06, 2009
    they either cannot or do not wish to help. No response to my email in over 4 days. Can anyone help in the UK? Kitchen / Lighting / Electrical distributors / wholesaler?
  • 10,865 Answers
Go the company web address and they will assist you.
www,kupperbuschusa.com/Hoods.asp
good luck and please rate my answer. thank you.
Posted on Feb 03, 2009
Wiring a cooker hood lamp holder
First off turn the power to the unit OFF.
On the side where the wires go in there is a small hole take a paper clip push it into the hole and the wire will be released. MAKE SURE THEIR IS NO POWER TO THE UNIT
Nov 20, 2013 | Cars & Trucks
HOOD LIGHT ON
I am not a car expert on this site but 50 years with cars has taught me some things---every vehicle I have seen with a light under the hood was activated by a plastic shaft that sticks up---hood is lifted and spring loaded shaft comes up and turns light on---should not be too hard to locate this with hood up.
At worst if you like I do not need or use this---remove the lamp/bulb under the hood so this does not run battery in vehicle down to point where it will not start---to the car experts on this site I answered this since no one else had.
Nov 03, 2012 | 2009 Volkswagen Routan
Where can I find a replacement plastic light cover for the left side of 5974890
not enough information but the best move will be to contact the service agent for the unit or manufacturer spares on the web page
Apr 02, 2012 | Faber Inca Smart 5974890 Kitchen Hood
I need to repalce one of the bulbs in my Miele Kitchen Hood, but I cannot work out how the bulb is removed. How is the bulb located? Should it screw out or just pull out? I don't want to force it in case I...
Remove the stainless steel outer filter
(see "Cleaning and care").
Pull the halogen lamp out of its
socket. Take care not to let the lamp
fall onto the hob below.
Insert the new halogen lamp into its
socket and carefully push into
position.
On the link below on page 27 tels you how.
http://www.miele.co.uk/Resources/OperatingInstructions/DA%20249-4.pdf
Now if that is not your hood please find the model # and you can get the manuakl on this link below.
http://www.miele.co.uk/customer/OperatingInstructions.aspx
Good Luck and please rate 4 thumbs up for the free answer
Aug 11, 2010 | Miele DA 249-4 Kitchen Hood
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 13, 2010 | KitchenAid KHLU162M Kitchen Hood
Need the glass hood for a Miele DA289 Range hood
hi,
you can only purchase Miele spares from Miele or through a Miele service agent. have a look on the Miele website for your nearest Miele branch
May 13, 2010 | Miele DA 289-4 Kitchen Hood
I need to buy a fan ..where can i get parts?
Hi lisa,
There are loads of online retailers, such as ourselves, who supply a huge selection of spares for cooker hoods. Hope that you'll have a look at our site. Here is the link to all our cooker hood spares.
Cheers,
eSpares
Mar 03, 2010 | TecnoWind isola d3 Stainless Steel Kitchen...
Risistor has blown on my CATA Kitchen hood, need a new one.
There is a spares company called 'Spares2go.co.uk' who provide parts for Cata extract hoods. I am find them very slow to respond to email queries. The contact tel No refers you back to their web site and to "be patient" !!!
Phil
May 02, 2009 | GE ZV750SY Kitchen Hood
Vent Hood
when a bulb blows, it takes excess current. if breaker is not sized to a hood, then damage to module can occur at time bulb goes
Apr 20, 2007 | KitchenAid KHTU165RSS Stainless Steel...
Ballast for fluorescent lamp
instal a day light lamp insted a white light one, the ballast is set to an specific watage...good luck
Aug 12, 2006 | Faber Cristal HC 598041 Kitchen Hood
Kitchen Ranges Logo
157 people viewed this question
Top Kuppersbusch Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kuppersbusch Kitchen Range Expert? Answer questions, earn points and help others
