Question about Bose LIFESTYLE 28 Series III System
I have a Bose Lifestyle 28 and want to hook my ipod up to it.
I have a Bose Lifestyle 28 and was hoping to get an ipod connection kit or something that would allow me to simply plug in my ipod so i can play it through the bose.
does anyone know if this is possible or if i need to purchase a connection kit.
as an FYI, I havwe the Lifestyle 28 connected to a Pioneer Kuro Plazma screen via a HDMI rack (4 slots). not sure if this helps.
  • Anonymous Feb 14, 2009
    I wanna play my ipod through the bose lifestyle 28.  It seems like this should be simple, but there's no plug for a simple 1/8th inch jack audio input
If there is a rca input available you can go to a local electronics store such as radio shack and pick up a rca MALE to 1/8 MALE cable
Posted on Feb 03, 2009
LIFESTYLE 28 Series III System: i have unique problem. My TV is connected to Bose ...
i would try changing ports right at the lifestyle unit ...make sure the port is good
May 18, 2010 | Bose LIFESTYLE 28 Series III System
PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
Jan 29, 2010 | Bose Lifestyle 28 System
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
How do I connect my ipod nano to my bose lifestyle 28?
tengo un Ipod nano 5° generation, con radio. Como lo escucho en el Bose?
Oct 03, 2009 | Bose Lifestyle 28 System
You can connect an iPod to your Bose V30 using an ipod dock, or simply with a mini-jack (headphone jack) to RCA cable plugged into your V30's Audio-In ports.
I hope that helps.
Download Bose LifeStyle V20 User Manual
Sep 13, 2009 | Bose Lifestyle V20 System - black Theater...
How do i connect a ipod to a bose lifestyle v30 system
You can connect your iPod to your Bose V30 using an ipod dock, or simply with a mini-jack (headphone jack) to RCA cable plugged into your V30's Audio-In ports.
I hope that helps.
Jun 07, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Same same here!
Any readily available Stereo RCA to Mini cable. These cables are a in stock item at any electronics store.
Plug Mini side of cable into ipod headphone jack and the RCA side of the cable into any available input on the Bose system, match color for color, Red to right and White to left. Select that input on your Bose system and use the ipod as normal. This is the cost effective solution.
The better choice is to use a after market ipod dock system such as DLO there are several levels to chose from all the way to HD outputs. These units can put your ipod display on your TV screen.
Jun 07, 2009 | Bose LIFESTYLE 28 Series III System
Bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Apr 05, 2009 | Bose Lifestyle 18 System
How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Jan 04, 2009 | Bose Lifestyle V20 System - black Theater...
Connecting lifestyle 27/38 to psp3
Your Bose system doesn't lead sound trough hdmi.
You must connect the optical cable with your lifestyle.
Change the sound connectionsettings in the menu of your ps3.
You also need to assgn the optical connection in the setup menu of the lifesyle. e.g. optical=aux.
Dec 28, 2008 | Bose Lifestyle 28 System
Bose LIFESTYLE 28 Series III System Logo
2,202 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
