Question about Intel D945GCCR Motherboard
Selecting Boot Device
I hsve two HD drives. One connect woth IDE with the CD drive. The seconds HD is a SATA drive. The bootup preference is boot from CD or boot from SATA. However, the IDE HD drive is stuck at right after the CD drive. How to setup correct drive in sequence (in the BIOS maybe?) so I do not need to press F10 to select?
    Problem Solver:
  • 14 Answers
If you want to boot from the IDE HD drive then you should get into BIOS and set it as the first boot device, followed by your SATA drive and CD drive. That should do the trick.
Hope this helps,
Sai.
Posted on Feb 03, 2009
This Emachine will not boot from HD or CD. The screen only says Emachine.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Computer will boot up with the external hard drive connected
if u dont want to bootup with external HD goto bios under boot device property first boot for {make it system intarnal HD}
Jun 26, 2010 | Maxtor OneTouch III Mini Edition 120GB...
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Seagate SATA 80GB Master Drive and Seagate IDE 80GB Salve Drive
Dear,
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
Thanks,
Rakesh Kumar
Jul 23, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
Boot up issues will not boot up from HD
IDE and SATA do not mix unless setup properly.
I would use the SATA one as main hard drive and set the other up as an external one on USB
Try resetting the BIOS to boot from CD
on ter lower part of boot screen will tel you the key to press to access the BIOS setup
Usually one of these keys
F2 CTRL+ESC or DEL
when in BIOS check and set to boot from CD
Nov 07, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
Intel D945GCCR Motherboard Logo
105 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
