Question about SanDisk Sansa e250 MP3 Player
My sansa player does not recognize a micro sd when its inserted
I have a 6 gb sansa and it has a slot for a micro sd. I want to either use the player to plug into my usb to transfer music from my computer to the micro, or even just access the memory itself from the player. It can doesnt seem to find it! i need help!!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 101,544 Answers
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
Posted on Jan 11, 2012
5 Suggested Answers
Mr_Wizardtex
  • 205 Answers
SOURCE: Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Posted on Jun 29, 2009
pacheco46
SOURCE: 2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Posted on Sep 18, 2009
PKwilDchilD
  • 44 Answers
SOURCE: how can i manage multiple micro sd cards on my sansa c250 MP3 player
it might not be possible. sorry.
Posted on May 22, 2008
  • 101544 Answers
SOURCE: can I attach an 8 GB Micro SD Card in the
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Posted on Mar 16, 2010
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
My PC does not recognise the Sansa express and it is not on
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Jun 16, 2009 | SanDisk Sansa MP3 Player
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
Micro sd memory card not recognized
Make sure your usb mode is msc plugin your sansa and go to my computer click on Sansa folder and you should see your removable disk this is your expansion card
Apr 17, 2009 | SanDisk Sansa e260 MP3 Player
I have a sansa e260, 4gb capacity, that has a spot for micro sd mini chips. I recently puchased a 4gb mini sd ghip that is 4 gb and loaded it up with about 3.89 gb of music and the sansa will not detect...
The Sansa, in common with many devices which have been around for a while, will only recognize standard micro SD up to 2 GB, not the SDHC (High Capacity) variety.
Feb 18, 2009 | SanDisk Sansa e260 MP3 Player
Sansa mp3 player could not detect micro sd add on card
I believe you can fix it by going on the player, then to settings, then to USB mode, and switching it from MTP to MSC. If you're in MSC already and it fails to recognize, then I don't know. :(
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
Trouble with expanded memory
The Sansa Express was only designed to hold up to a 2 GB Micro SD card because that is as much expandable memory it was meant to read. Anything bigger as in your case will cause the player to go slower than normal as it tries to read the card and after a while, it will most likely freeze. If you try it with a 2 GB Micro SD card, it should work.
Dec 10, 2008 | SanDisk Sansa MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
