Question about NEC PowerMate eco PC Desktop
Powermate Eco Hard Drive Crashed
I have an NEC Powermate Eco. The hard drive crashed. How can I replace it and what type can I replace it with?
  • 5 more comments
  • ebmvegan Feb 03, 2009
    I removed the front bay as directed by the instructions. Are the optical and hard drives all in one case? The case reads, "TEAC CD-224E"
    MODEL VER. -CN4
    PART NO. 1977047C-N4
    SERIAL NO. 2451026
    Thank you.
    Ben
    Once removed, the unit looks just like an optical drive.
    Can you point out the hard drive
    Found it!
    Info on the drive states the following:
    MK2018GAS
    HDD2168
    There are 24 pins on top and 23 on the bottom to connect to the the cable.
  • ebmvegan Feb 05, 2009
    You ROCK! I was able to purchase the new hard drive. Unfortunately, the bios only supports up to a 40G drive and I couldn't go any higher. Thank you.
  • GottoLinux Apr 27, 2009
    Nice pics, how about upgrading/replacing the bios on the NEC Powermate Eco? I need to replace the bios, I am getting the 1-2-2-3 beep instead of a boot up. Substituted the hd and ram, neither did the job. Know what chip it is? And how to flash the bios? There is no floppy drive. Will flash thumb drive work?
  • NEC Master
  • 13,433 Answers
Hello
instructions on how to remove and replace the hard drive are on this PDF document.
http://support.necam.com/mobilesolutions/hardware/Desktops/eco/819-201002-000med.pdf
You will need a pdf reader to open the document, if you are unable to open it download a pdf reader here
http://www.adobe.com/products/reader/
Can you remove the hard drive from the computer, write down the details that read on top of it, and also if you could look at the connectors and tell me the details so I can make sure I direct you at a proper replacement.
Thank you,
Ekse
Posted on Feb 03, 2009
  • 7 more comments
  • Ekse Feb 03, 2009
    Ok, That seems to be the cd drive. Is there another drive under the cd drive? I'll have to look into this more then.
  • Ekse Feb 03, 2009
    The document said that, you can remove optical drive and hard drive by doing that, so I suppose the hard drive is below the cd drive. What does it look like?
  • Ekse Feb 03, 2009
    Ok I see, there is just the cd/dvd there. The hard drive must be at another location I will look into it.
  • Ekse Feb 03, 2009
    Hi again,
    If on the stand you only have the optical drive and there is no room for a hard drive there. Then it must be inside the back of the display.
    Heres the user guide which has instructions on how to upgrade the ram.
    http://support.necam.com/mobilesolutions...
    we aren't actually upgrading the ram, but this should be helpful in takeing the computer apart and finding the hard drive that is inside.
    See page 9.
    The manual also contains the contact details of nec support incase you don't want to go in yourself to find out where it is, you could email Tech-support@nec-computers.com and wait a day or two for the answer.
    Looking at the picture of the computer, the System board shield would need to come off to see the internals.
    I can see a wide flex cable that might be connected to the hard drive. but I've never been inside this computer or used it so I may very well be wrong. but in anycase if you want to find out where the hard drive is. It should be standard IDE - cheap and easyly available. I suspect you may need to remove the system board shield to see everything inside.
  • Ekse Feb 03, 2009
    I don't see it on this picture
    do you see this style of connector?
    or this style of cable?
    Looking at your picture
    Two possible cables there. Whats on the other ends?
  • Ekse Feb 03, 2009
    we may have to take the whole thing apart to find it. Let me know what you find at the other end of that silverish cable and that other flex cable.
  • Ekse Feb 03, 2009
    the picture didn't come out very well, too small. can you take the hard drive out? can you get me some details from it and a picture possibly? from connectors also? and I'll tell you what you need.
    Thanks.
  • Ekse Feb 04, 2009
    Hi
    Its a standard 2.5" laptop hard drive - ata
    heres the documents for the drive if your intrested
    http://sdd.toshiba.com/techdocs/MK2018GA...
    These driver are available on ebay for example
    http://computers.shop.ebay.com/items/Dri...
    The computer should support atleast few hundred GB drive. but if you want to be on the safe side the 20 and 40GB drives should work 100%. bigger drives should also work but if they don't then the bios doesn't support that big of a drive. 20-40GB is a safe bet. you can try bigger.
    Anything Else?
    Thanks,
    Ekse
  • Ekse Feb 05, 2009
    do you need further assistance? I would appriciate it if you could rate my support if you have gotten the problem solved or let me know if you have any questions.
My nec powermate p3020 is automatically getting shutdown as soon as windows loaded
Hi
Have you tried your hard drive on another machine?Or maybe tried another hard drive on your machine?
Could well be a faulty hard drive.
Also try disconnecting the hard drive and connecting it again.
Feb 28, 2012 | NEC Computers & Internet
Hi , I have a Powermate Eco and after moving house it will not start up. It usually has the LED go green on power up and the hard drive kicks in and starts but now it flickers green but then goes amber and...
There might be a fault with the power supply. Take it to your local computer repair shop and they will be more than happy to test it for you for free.
Dec 18, 2009 | NEC PowerMate eco PC Desktop
Hi, My hard drive recently crashed. Can you suggest a replacement? I have SP1203N now.
Hi
My hard drive also crashed and I installed a Samsung SP2514N 250 GB and I found it very good.
Give it a try.
Nov 11, 2009 | Samsung (SP1203N) 120 GB Hard Drive
Averatec serie 3200 crashed new hard drive need drivers
the same way you typed it here try google it gives you the drivers then you install.
Jul 04, 2009 | Averatec 3200 Notebook
Hard crash, Need To Replace BIOS
If you're not good at sodering I'd suggest replacing the whole motherboard. Otherwise go Here <<< for a guide on the bios, and how to replace it.
Apr 27, 2009 | NEC PowerMate eco PC Desktop
What hard drive will work with my NEC PowerMate 5250?
you would need to get the manual for this computer as the manual should state in it what type of hard drive it supports in terms of capacity and what connector types it needs ie IDE or SATA ?
Also are there any bios updates for this computers motherboard as that may resolve you not being able to attach a large capacity hard drive also in the bios see if you can enable LBA (logical block addressing ) http://www.pcguide.com/ref/hdd/bios/modesLBA-c.html or there may be another setting in the bios which may help you.
Apr 09, 2009 | NEC PowerMate 5250 PC Desktop
Hard Drive
what do you mean with "crashed" ?
if your harddrive is dead, you need to replace your hdd.
if your OS is crashed, try to go to safe mode and backup your data, and reload the OS.
if you have software to diagnostic your hdd and rams it would be good to diagnostic that. it might found what it cause your hdd crashed
Aug 09, 2008 | Acer Aspire 3680 Laptop
Cannot find hard drive error after repair
Couldn't find the hard drive or the DVD drive? If it's the hard drive then the crash was due to a hard drive failure and the hard drive will have to be replaced. If it's the DVD drive, you will need to get a floppy for it and flash the bios in order for the machine to recognize the DVD drive again.
Jul 22, 2008 | IBM ThinkPad T30 2366 Notebook
Crashed Hard Drive
Dear User
If your hardisk is crashed then your computer cannot detect it so its good to replace it if its under warranty
Feb 12, 2008 | Western Digital Caviar WD2500BB 250 GB...
NEC PowerMate eco PC Desktop Logo
340 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
