Sony KP-46WT510 Rear Video Projector Convergence Problem
I have had this television for almost 5 years; the manufactured date was July 2003. One day, the image on the television was all screwed up:
There is a concave image(middle part of the picture bending in and the outer ends bending out)
The red-blue-green colors were separated so it looked like 3 images at once
It's all blurry with color messes everywhere. There are red and green lines at the ends. It also has the same problem with my DVD/VCR. Convergence menu and flash-focus doesn't work - otherwise the t.v works perfectly fine. From all the other questions, I think the problem is something about replacing convergence amps, whatever that is. But I'm not circuitry-savvy so I don't know what in the world I have to do to fix it. What items do I need, where can I get it, how much will it cost, how will I fix it and is it advisable for someone to look at it or will I be able to do it myself? (I'm handy at fixing things) Is there anyone willing to share their time? Thanks a bunch. exact same problem
Re: Sony KP-46WT510 Rear Video Projector Convergence...
The diagnosis you have made is correct. The Convergence amps are not working up to their optimum power causing the image to come in a concave shape. These amps are necessary for positioning the image in x&y co-ordinates accordingly. If you are not a circuit savvy then, I would recomend you to take it to the technician or a service centre.
Thanks
Rate it as a Fixya if you find the solution satisfying
Welcome to Fixya! Solution: You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, pico fuses, etc. Everything you need to fix it yourself. Its an easy fix. Please Rate My Response! Thanks!
If the convergence feature did not fix the issue then you will need to install a convergence repair kit. Your model uses the Sony type 1 convergence repair kit which is available from www.tvrepairworld.com and includes the parts and the CD with instructions.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Convergence out ICsare located on D Board of Sony KP-46WT510 These are 2 big ICs of black color mounted on silver heat sink. Check out location of D board in TV in below exploded view...
Unfortunately it is a job that will require an experienced TV technician, You have 2 large 18 pin ICs called convergence amplifiers who's job is to insure beam alignment of the three picture tubes in your TV set (Red, Green & Blue). One of the 2 chips have shorted and more than likely cause damage to the 2nd one as well. This involves removing the board where the ICs are mounted then rmoving the ICs by a process called desoldering & resoldering during the replacement process. They are not a plug in Ics. Hope this helps.
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Symptoms / Customer Description Video bowed in and convergence is out. [Primary Symptom Code: 1436 ]
Solution
Found PS5001 on G board was open.
HQ
Comments: Could be cold solder joint on one of the STK IC's on the D
Board. They run hot and the solder connection might have broken down
causing intermittent condition which could have opened the fuse on the -22v line.
